bootstrap error
dave daveerickson at shaw.ca
Sat Oct 12 16:52:15 UTC 2013
Ok bootstrap completed, I created a fresh directory and started a configure:
According to the Getting Started manual, the --target=i386-rtems4.11
According to the rtems/c/TOOL_TARGETS  the targets is called i386-rtems
I tried several versions of  i386-rtems  i386-rtems4.11 i386-rtems-4.11
and this is the compiler fail:
[dave at localhost build-i386]$ ../rtems/configure --target=i386-rtems4.11
--enable-posix --enable-networking --disable-cxx
--enable-rtemsbsp="pc386" --prefix=/opt/rtems-4.11
checking for gmake... gmake
checking for RTEMS Version... 4.10.99.0
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... i386-pc-rtems4.11
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether gmake sets $(MAKE)... yes
checking whether gmake supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking that generated files are newer than configure... done
configure: creating ./config.status
configure: configuring in ./tools/build
configure: running /bin/sh '../../../rtems/tools/build/configure'
'--prefix=/opt/rtems-4.11' '--host=x86_64-unknown-linux-gnu'
'--build=x86_64-unknown-linux-gnu'  '--enable-posix'
'--enable-networking' '--disable-cxx' '--enable-rtemsbsp=pc386'
'--target=i386-rtems4.11'  '--cache-file=/dev/null'
'--srcdir=../../../rtems/tools/build'
checking for x86_64-unknown-linux-gnu-gcc... no
checking for gcc... no
checking for x86_64-unknown-linux-gnu-cc... no
checking for cc... no
checking for x86_64-unknown-linux-gnu-cl.exe... no
checking for cl.exe... no
configure: error: in `/home/dave/src/RTEMS/build-i386/tools/build':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details
configure: error: /bin/sh '../../../rtems/tools/build/configure' failed
for tools/build
Here is my path
[dave at localhost build-i386]$ echo $PATH
/opt/rtems-4.11/i386-rtems4.11:/opt/rtems-4.11/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/home/dave/.local/bin:/home/dave/bin
On 10/12/2013 03:21 AM, Ralf Corsepius wrote:
> On 10/12/2013 05:31 AM, dave wrote:
>> Hello;
>> I switched to Fedora 19 from Ubuntu and loaded all build tools and
>> the loaded git source.
>> I ran the bootstrap and got then got this error:
>> ./bootstrap
>> Can't locate Thread/Queue.pm in @INC (@INC contains:
>> /opt/rtems-4.11/share/automake-1.13 /usr/local/lib64/perl5
>> /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl
>> /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at
>> /opt/rtems-4.11/bin/automake line 140.
>> BEGIN failed--compilation aborted at /opt/rtems-4.11/bin/automake
>> line 143.
>> autoreconf: automake failed with exit status: 2
>> grep: Makefile.in: No such file or directory
>> ./testsuites/libtests
> Definitely a packaging bug. I don't know the cause, yet - To be
> investigated.
> In the meantime, try
> # yum install 'perl(Thread::Queue)'
> Ralf
