[solved] Re: shared library with rtems
Wed Oct 2 13:51:56 UTC 2013
On 10/2/2013 6:14 AM, Luca Cinquepalmi wrote:
> I used LINK_LIBS = -lMyLib
> and it works!
Links? Runs?
FYI the git modules rtl and rtl-host include dynamic
loading support.
--joel
> Il 02/10/2013 12:57, Gedare Bloom ha scritto:
>> Check that the symbols are in your shared library file, for example with:
>> sparc-rtems4.11-nm libmyLib.a > symbols.txt
>> and then look in symbols.txt. The error indicates the library is not
>> being loaded correctly at link time.
>> -Gedare
>> On Wed, Oct 2, 2013 at 5:37 AM, Luca Cinquepalmi
>> <cinquepalmi at planetek.it> wrote:
>>> Now I'm able to integrate my shared libraries,
>>> but the compiler is not able to find the funcions implemented
>>> in it:
>>> OBSW_Xmain.cc:(.text+0x68): undefined reference to
>>> `HWDRV_Driver::addCanDevice(HWDRV_Device)'
>>> I don't think to add cpp soruce file... Can you please tell me what is the
>>> problem?
>>> I just included header files...
>>> Thanks
>>> Luca
>>> Il 01/10/2013 14:41, Luca Cinquepalmi ha scritto:
>>> Shall I use -B instead of -L option in compiling?
>>> Il 01/10/2013 13:36, Wendell Silva ha scritto:
>>> Well, it should work...
>>> Could you, please, post the entire command line? The lower case L ('l')
>>> sounds very simililar to upper case "i" ('I').
>>> 2013/10/1 Luca Cinquepalmi <cinquepalmi at planetek.it>
>>>> Yes, sure!
>>>> Il 01/10/2013 13:15, Wendell Silva ha scritto:
>>>> Is there a file named libtestLib.a in lib_path?
>>>>> Hi all,
>>>>> I'm trying to compile a shared library with sparc-rtems-gcc,
>>>>> by using the options -I (include), -L(lib_path) and -l(library)
>>>>> but the following message appear
>>>>> ld: cannot find -ltestLib
>>>>> Shall i use different options? How you tried to do it in a different way?
>>>>> Thanks
>>>>> Luca
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.org
>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
