Gaia Update Request
Jiri Gaisler
jiri at gaisler.se
Fri Oct 25 08:25:20 UTC 2013
It could be worth mentioning that the PDMU is based on the
ERC32 (TSC695) SPARC V7 processor, while the PDHU is using
a LEON2FT (AT697) SPARC V8 chip. A simple data sheet for the
PDHU can be found here :
http://www.syderal.ch/images/allproductsheets/gaia%20pdhu%20product%20syd.pdf
Jiri.
On 10/25/2013 09:56 AM, Zandin Johan RUAG wrote:
> Joel Sherrill wrote:
>> Any ideas which subsystems run RTEMS?
> The Gaia CDMU from RUAG Space AB runs RTEMS 4.6.1.
> I just added this on http://wiki.rtems.org/wiki/index.php/GAIA
> where I also saw that the PDHU was already mentioned.
>> FWIW I have wanted to run a launch count down on rtems.org
>> for each launch that includes some RTEMS based system.
>> It just seems hard to track them. :(
> I think this would be a good starting point, at least for the
> ones reasonably close in time:
> http://spaceflightnow.com/tracking/
> /Johan
> Johan Zandin Computer Engineer
> RUAG Space AB Phone: +46-31-735 41 47
> SE-405 15 Gothenburg, Sweden Fax: +46-31-735 40 00
> rtems-users mailing list
> rtems-users at rtems.org
