Important Question : Adding a Periodic task to the RTEMS using a special scheduler : EDF
Mohammed Khoory mkhoory at eiast.ae
Mon Sep 16 00:49:30 UTC 2013
I believe you can the Rate Monotonic Manager directives provided by RTEMS.
It's useful for cases where you have real-time constraints and can also
gather statistics. More details are found in the C User's guide, located
here:
http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.10.2/share/rtems/html/
There's also the Timer Manager which does a similar job, but it's simpler
and doesn't have the rigid real-time constraints that the Rate Monotonic
Manager has, from what I understood. (please correct me if I'm wrong on
this)
From: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org]
On Behalf Of Golnaz Saraji
Sent: Monday, September 16, 2013 12:38 AM
To: rtems-users at rtems.org
Subject: Fwd: Important Question : Adding a Periodic task to the RTEMS using
Hello!
I have a request :
Please tell me how can I add a periodic task which RTEMS run it
periodically;
Can we use the operating systems utilities to do so?
for example I have a thread which it must run every 10 ms; How can tell to
RTEMS to run it on EDF scheduler?
please help me to understand it;
Regards!
Golnaz.Saraji
URL: <http://lists.rtems.org/pipermail/users/attachments/20130916/bb60ca2d/attachment-0001.html>
