Latest RTEMS without posix support
Serg Kruglov skruglov at nm.ru
Wed Apr 2 15:12:34 UTC 2014
Sent: Wednesday, April 02, 2014 6:46 PM
To: Serg Kruglov ; rtems-users at rtems.org
Subject: Re: Latest RTEMS without posix support
I configure with:
/opt/rtems-4.11/rtems-master/configure --target=mips-rtems4.11 --enable-rtemsbsp="genmongoose" --disable-networking --disable-itron --disable-cxx --enable-rtems-debug=yes --disable-multiprocessing --enable-maintainer-mode –disable-posix --enable-test=yes
gcc 4.8.2 with mingw64 directory , newlib 2.0.0 with mips patches (signal patch not implemented)
Also with –enable-posix testsuites build, only samples directory
If run fileio.exe test and select “run shell” : rtems_libio_set_private_env(): (status: RTEMS_TOO_MANY)
URL: <http://lists.rtems.org/pipermail/users/attachments/20140402/9c3bb32a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20140402/9c3bb32a/attachment-0001.png>
