Window Tools was Re: Latest RTEMS without posix support
Serg Kruglov
skruglov at nm.ru
Thu Apr 3 06:33:07 UTC 2014
$ mips-rtems4.11-gcc -v
Using built-in specs.
COLLECT_GCC=C:\msys\opt\rtems-4.11\bin\mips-rtems4.11-gcc.exe
COLLECT_LTO_WRAPPER=c:/msys/opt/rtems-4.11/bin/../libexec/gcc/mips-rtems4.11/4.8
.2/lto-wrapper.exe
Target: mips-rtems4.11
Configured with: ../gcc-4.8.2/configure --build=i686-w64-mingw32 --prefix=/opt/r
tems-4.11 --target=mips-rtems4.11 --disable-libstdcxx-pch --with-gnu-as --with-g
nu-ld --verbose --with-newlib --with-static-zlib --disable-nls --without-include
d-gettext --disable-win32-registry --enable-threads --disable-lto --disable-plug
in --enable-newlib-io-c99-formats --enable-newlib-iconv --enable-languages=c --e
nable-static --disable-shared --with-gmp=/usr/local --with-mpfr=/usr/local --wit
h-mpc=/usr/local --with-libiconv-prefix=/usr/local --with-stage1-ldflags='-s -st
atic-libstdc++ -static-libgcc' --with-host-libstdcxx=/mingw/lib/gcc/i686-w64-min
gw32/4.7.3/libstdc++.a CFLAGS='-g -O2' CXXFLAGS='-g -O2' CPPFLAGS=-fexceptions L
DFLAGS='-s -static-libstdc++ -static-libgcc'
Thread model: posix
gcc version 4.8.2 (GCC)
$ mips-rtems4.11-gcc --version
mips-rtems4.11-gcc.exe (GCC) 4.8.2
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
I don’t use binary packages: my CPU only “like” mongoose R3000 (have some specific bugs) and I patch he bugs in patched as.exe (custom patched binutils).
I download source from http://www.rtems.org/ftp/pub/rtems/mingw64/4.11/i686/rtems-4.11-mips-rtems4.11-gcc/
and newlib 2.0.0 http://sourceforge.net/projects/devkitpro/files/sources/newlib/
patches in github rtems-tools
If this mistake, please send my correct downloads paths (or archive with needed source code and patches for mips CPU)
URL: <http://lists.rtems.org/pipermail/users/attachments/20140403/b372dded/attachment-0001.html>
