Installing interrupts for a custom driver
Needell Gerald
jerry.needell at unh.edu
Fri Apr 4 16:09:16 UTC 2014
You should be able to just call:
old_handler = setvector((rtems_isr_entry)UARTInterruptHandler, (rtems_vector_number)3, 1);
On Apr 4, 2014, at 11:37 AM, Needell Gerald <jerry.needell at unh.edu> wrote:
> Alberto,
> No. My suggestion is to use the rtems_interrupt_catch but then enable the interrupt as in the example .
> -Jerry
> On Apr 4, 2014, at 11:33, Alberto Parnaso <pafbat00 at yahoo.es> wrote:
>> Hi Jerry, thank you very much for your response. If I have understand correctly I may have to install the interrupt not with "rtems_interrupt_catch" but using "_CPU_ISR_install_raw_handler". Is that correct? I am out of work now but I will test it on Monday and come back with the results. Thanks indeed!
>> Alberto.
>> De: Needell Gerald <jerry.needell at unh.edu>
>> Para: Alberto Parnaso <pafbat00 at yahoo.es>
>> CC: Jerry Needell <jerry.needell at unh.edu>; RTEMS Send User List <rtems-users at rtems.org>
>> Enviado: Viernes 4 de abril de 2014 16:25
>> Asunto: Re: Installing interrupts for a custom driver
>> Alberto,
>> This may not have been correct- Take a look at the c/src/lib/libbsp/sparc/leon3/startup/setec.c function from the LEON3 BSP (RTEMS 4.9.2) - attached:
>> After calling rtems_catch_interrupt the LEON3 interrupt is then enabled - I install my handlers as a type=1 RTEMS interrupt.
>> I hope that helps
>> - Jerry
>> /* set_vector
>> * This routine installs an interrupt vector on the SPARC simulator.
>> * INPUT PARAMETERS:
>> * handler - interrupt handler entry point
>> * vector - vector number
>> * type - 0 indicates raw hardware connect
>> * 1 indicates RTEMS interrupt connect
>> * OUTPUT PARAMETERS: NONE
>> * RETURNS:
>> * address of previous interrupt handler
>> * COPYRIGHT (c) 1989-1998.
>> * On-Line Applications Research Corporation (OAR).
>> * The license and distribution terms for this file may be
>> * found in the file LICENSE in this distribution or at
>> * http://www.rtems.com/license/LICENSE.
>> * Ported to LEON implementation of the SPARC by On-Line Applications
>> * Research Corporation (OAR) under contract to the European Space
>> * Agency (ESA).
>> * LEON modifications of respective RTEMS file: COPYRIGHT (c) 1995.
>> * European Space Agency.
>> * $Id: setvec.c,v 1.2 2006/01/09 10:41:21 ralf Exp $
>> #include <bsp.h>
>> rtems_isr_entry set_vector( /* returns old vector */
>> rtems_isr_entry handler, /* isr routine */
>> rtems_vector_number vector, /* vector number */
>> int type /* RTEMS or RAW intr */
>> rtems_isr_entry previous_isr;
>> uint32_t real_trap;
>> uint32_t source;
>> if ( type )
>> rtems_interrupt_catch( handler, vector, &previous_isr );
>> else
>> _CPU_ISR_install_raw_handler( vector, handler, (void *)&previous_isr );
>> real_trap = SPARC_REAL_TRAP_NUMBER( vector );
>> if ( LEON_INT_TRAP( real_trap ) ) {
>> source = LEON_TRAP_SOURCE( real_trap );
>> LEON_Clear_interrupt( source );
>> LEON_Unmask_interrupt( source );
>> return previous_isr;
>> On Apr 4, 2014, at 9:33 AM, Needell Gerald <jerry.needell at unh.edu> wrote:
>> Alberto,
>> If I recall correctly, rtems_interrupt_catch installs the new interrupt handler, but does not enable it. You will also need to call rtems_interrupt_enable.
>> Good luck!
>> Jerry
>> On Apr 4, 2014, at 9:12 AM, Alberto Parnaso <pafbat00 at yahoo.es> wrote:
>>> Hi, I am newbie in RTEMS and I am trying to install an interrupt into the interrupt controller to be capable of using an APBUART peripheral within a LEON3 based embedded processor. I configure the system so driver manager configures at BSP Start the console and the timer. I do have two APBUART configured in the system and my intention is to use the first one with console/termios driver and the second one with my own driver. Here is a copy the output of "info sys" command:
>>> grmon2> info sys
>>> cpu0 Aeroflex Gaisler LEON3 SPARC V8 Processor
>>> AHB Master 0
>>> ahbjtag0 Aeroflex Gaisler JTAG Debug Link
>>> AHB Master 1
>>> mctrl0 European Space Agency LEON2 Memory Controller
>>> AHB: 00000000 - 20000000
>>> AHB: 20000000 - 40000000
>>> AHB: 40000000 - 80000000
>>> APB: 80000000 - 80000100
>>> 32-bit prom @ 0x00000000
>>> 32-bit static ram: 2 * 512 kbyte @ 0x40000000
>>> apbmst0 Aeroflex Gaisler AHB/APB Bridge
>>> AHB: 80000000 - 80100000
>>> dsu0 Aeroflex Gaisler LEON3 Debug Support Unit
>>> AHB: 90000000 - A0000000
>>> CPU0: win 8, hwbp 2, V8 mul/div, lddel 1, GRFPU-lite
>>> stack pointer 0x400ffff0
>>> icache 1 * 4 kB, 32 B/line
>>> dcache 1 * 4 kB, 32 B/line
>>> uart0 Aeroflex Gaisler Generic UART
>>> APB: 80000100 - 80000200
>>> IRQ: 2
>>> Baudrate 38343
>>> irqmp0 Aeroflex Gaisler Multi-processor Interrupt Ctrl.
>>> APB: 80000200 - 80000300
>>> gptimer0 Aeroflex Gaisler Modular Timer Unit
>>> APB: 80000300 - 80000400
>>> IRQ: 8
>>> 8-bit scalar, 2 * 32-bit timers, divisor 50
>>> uart1 Aeroflex Gaisler Generic UART
>>> APB: 80000900 - 80000A00
>>> IRQ: 3
>>> Baudrate 38343
>>> gpio0 Aeroflex Gaisler General Purpose I/O port
>>> APB: 80000B00 - 80000C00
>>> I have wrote a testing app to check if both UARTs work and also to try to install a handler for RX on the second UART. Here is my code:
>>> #include <rtems.h>
>>> rtems_task Init( rtems_task_argument argument); /* forward declaration needed */
>>> /* configuration information */
>>> #define CONFIGURE_INIT
>>> #include <bsp.h> /* for device driver prototypes */
>>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>> #define CONFIGURE_MAXIMUM_TASKS 4
>>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>> #include <rtems/confdefs.h>
>>> #include <stdio.h>
>>> #include <stdlib.h>
>>> #include <sys/types.h>
>>> #include <sys/stat.h>
>>> #include <unistd.h>
>>> #include <errno.h>
>>> #include <apbuart.h>
>>> // Global Variable to check if Interrupt has been signaled.
>>> unsigned char uc_intr_flag;
>>> // Interrupt handler for APBUART peripheral
>>> void UARTInterruptHandler ()
>>> uc_intr_flag = 1;
>>> rtems_task Init (rtems_task_argument ignored)
>>> int i;
>>> rtems_status_code ret_status;
>>> rtems_isr_entry old_handler;
>>> volatile int *apbuart1 = (int*)0x80000900;
>>> volatile int aux;
>>> // Reset Interrupt Flag
>>> uc_intr_flag = 0;
>>> printf("APB UART TEST with Interrupts\n");
>>> aux = apbuart1[1];
>>> printf("APBUART1 STATUS: 0x%08X\n", aux);
>>> aux = apbuart1[2];
>>> printf("APBUART1 CONTROL: 0x%08X\n", aux);
>>> // Install UARTInterruptHandler at vector number 3
>>> ret_status = rtems_interrupt_catch(
>>> &old_handler);
>>> switch (ret_status)
>>> case RTEMS_SUCCESSFUL :
>>> printf("rtems_interrupt_catch: OK. New Interrupt installed for IRQ 3 - APBUART 2.\n");
>>> break ;
>>> case RTEMS_INVALID_NUMBER :
>>> printf("rtems_interrupt_catch: RTEMS_INVALID_NUMBER.\n");
>>> break ;
>>> case RTEMS_INVALID_ADDRESS :
>>> printf("rtems_interrupt_catch: RTEMS_INVALID_ADDRESS.\n");
>>> break ;
>>> default :
>>> printf("rtems_interrupt_catch: Unknown error.\n");
>>> break ;
>>> // Tell uart hardware to initialize directly
>>> /* Enable receiver (with interrupts) & Transmitter */
>>> apbuart1[2] = APBUART_CTRL_RE | APBUART_CTRL_TE | APBUART_CTRL_RI;
>>> aux = apbuart1[1];
>>> printf("UART1 STATUS: 0x%02X\n", aux);
>>> aux = apbuart1[2];
>>> printf("UART1 CONTROL: 0x%08X\n", aux);
>>> // Write a character though APBUART1 to test it
>>> apbuart1[0] = 0xD8;
>>> while (1)
>>> { // Perform some active wait time
>>> for (i = 2000000; i > 0; i--);
>>> printf("Hello World\n");
>>> apbuart1[0] = 0xD8;
>>> // If interrupt received, read from APBUART
>>> if (uc_intr_flag == 1)
>>> uc_intr_flag = 0;
>>> aux = apbuart1[0];
>>> printf("Interrupt received from UART: data = %X\n", aux);
>>> exit (0);
>>> First UART (ie. debug UART) works fine and output data through STDOUT properly. Data sent through second UART is received also by another external terminal, and in other test I have been capable of receiving too. However UARTInterruptHandler is never signaled, thus I guess I am missing something with the interrupt instalation.
>>> Could any one see anything missing in this code? I would very much appreciate some help. Any clue on how to properly use interrupts will help me a lot!
>>> Thanks!
>>> Alberto.
>>> rtems-users mailing list
>>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140404/033da2f5/attachment-0001.html>
