Installing interrupts for a custom driver
Alberto Parnaso
pafbat00 at yahoo.es
Mon Apr 7 10:58:50 UTC 2014
I have tried the set_vector functions and didn't work either. I though that Driver Manager may be interfering with the interrupt controller driver and I decided to avoid it by "#undef RTEMS_DRVMGR_STARTUP" and see if my handler was being called, but nothing at all. Then I wanted to know if the interrupt was being signaled in the interrupt controller so I went to the IRQ Pending register of the GAISLER_IRQMPIP Core, and as soon as I introduce any character from external terminal towards the APBUART, the Interrupt is shown in the register, but my handler is never called.
It is quite disappointing, I have to say. Installing an interrupt should be something easy to do, or at least it has been when working with other OS ... I don't know. Any help will be welcome.
Alberto.
________________________________
De: Needell Gerald <jerry.needell at unh.edu>
Para: Alberto Parnaso <pafbat00 at yahoo.es>
CC: Needell Gerald (Jerry) <jerry.needell at unh.edu>; RTEMS Send User List <rtems-users at rtems.org>
Enviado: Viernes 4 de abril de 2014 18:09
Asunto: Re: Installing interrupts for a custom driver
You should be able to just call:
old_handler = setvector((rtems_isr_entry)UARTInterruptHandler, (rtems_vector_number)3, 1);
On Apr 4, 2014, at 11:37 AM, Needell Gerald <jerry.needell at unh.edu> wrote:
Alberto,
No. My suggestion is to use the rtems_interrupt_catch but then enable the interrupt as in the example .
-Jerry
On Apr 4, 2014, at 11:33, Alberto Parnaso <pafbat00 at yahoo.es> wrote:
Hi Jerry, thank you very much for your response. If I have understand correctly I may have to install the interrupt not with "rtems_interrupt_catch" but using "_CPU_ISR_install_raw_handler". Is that correct? I am out of work now but I will test it on Monday and come back with the results. Thanks indeed!
>Alberto.
>CC: Jerry Needell <jerry.needell at unh.edu>; RTEMS Send User List <rtems-users at rtems.org>
>Enviado: Viernes 4 de abril de 2014 16:25
>Alberto,
>This may not have been correct- Take a look at the c/src/lib/libbsp/sparc/leon3/startup/setec.c function from the LEON3 BSP (RTEMS 4.9.2) - attached:
>After calling rtems_catch_interrupt the LEON3 interrupt is then enabled - I install my handlers as a type=1 RTEMS interrupt.
>I hope that helps
>- Jerry
>/* set_vector
> * This routine installs an interrupt vector on the SPARC simulator.
> * INPUT PARAMETERS:
> * handler - interrupt handler entry point
> * vector - vector number
> * type - 0 indicates raw hardware connect
> * 1 indicates RTEMS interrupt connect
> * OUTPUT PARAMETERS: NONE
> * RETURNS:
> * address of previous interrupt handler
> * COPYRIGHT (c) 1989-1998.
> * On-Line Applications Research Corporation (OAR).
> * The license and distribution terms for this file may be
> * found in the file LICENSE in this distribution or at
> * http://www.rtems.com/license/LICENSE.
> * Ported to LEON implementation of the SPARC by On-Line Applications
> * Research Corporation (OAR) under contract to the European Space
> * Agency (ESA).
> * LEON modifications of respective RTEMS file: COPYRIGHT (c) 1995.
> * European Space Agency.
> * $Id: setvec.c,v 1.2 2006/01/09 10:41:21 ralf Exp $
>#include <bsp.h>
>rtems_isr_entry set_vector( /* returns old vector */
> rtems_isr_entry handler, /* isr routine */
> rtems_vector_number vector, /* vector number */
> int type /* RTEMS or RAW intr */
> rtems_isr_entry previous_isr;
> uint32_t real_trap;
> uint32_t source;
> if ( type )
> rtems_interrupt_catch( handler, vector, &previous_isr );
> else
> _CPU_ISR_install_raw_handler( vector, handler, (void *)&previous_isr );
> real_trap = SPARC_REAL_TRAP_NUMBER( vector );
> if ( LEON_INT_TRAP( real_trap ) ) {
> source = LEON_TRAP_SOURCE( real_trap );
> LEON_Clear_interrupt( source );
> LEON_Unmask_interrupt( source );
> return previous_isr;
>On Apr 4, 2014, at 9:33 AM, Needell Gerald <jerry.needell at unh.edu> wrote:
>Alberto,
>If I recall correctly, rtems_interrupt_catch installs the new interrupt handler, but does not enable it. You will also need to call rtems_interrupt_enable.
>Good luck!
>Jerry
>On Apr 4, 2014, at 9:12 AM, Alberto Parnaso <pafbat00 at yahoo.es> wrote:
>Hi, I am newbie in RTEMS and I am trying to install an interrupt into the
interrupt controller to be capable of using an APBUART peripheral within a LEON3 based embedded processor. I configure the system so driver
manager configures at BSP Start the console and the timer. I do have two APBUART configured in the system and my intention is to use the first
one with console/termios driver and the second one with my own driver.
Here is a copy the output of "info sys" command:
>>grmon2> info sys
>> cpu0 Aeroflex Gaisler LEON3 SPARC V8 Processor
>> AHB Master
0
>> ahbjtag0 Aeroflex Gaisler JTAG Debug Link
>> AHB Master 1
>> mctrl0 European Space Agency LEON2 Memory Controller
>> AHB: 00000000 - 20000000
>> AHB: 20000000 - 40000000
>> AHB: 40000000 - 80000000
APB: 80000000 -
80000100
>> 32-bit prom @ 0x00000000
>> 32-bit static ram: 2 * 512 kbyte @ 0x40000000
>> apbmst0 Aeroflex Gaisler AHB/APB Bridge
>> AHB: 80000000 - 80100000
>> dsu0 Aeroflex Gaisler LEON3 Debug Support Unit
>> AHB: 90000000 - A0000000
CPU0: win 8, hwbp 2, V8 mul/div, lddel 1, GRFPU-lite
stack pointer 0x400ffff0
>> icache 1 * 4 kB, 32 B/line
>> dcache 1 * 4 kB, 32 B/line
>> uart0 Aeroflex Gaisler Generic UART
>> APB: 80000100 - 80000200
>> IRQ: 2
>> Baudrate 38343
>> irqmp0 Aeroflex Gaisler Multi-processor
Interrupt Ctrl.
>> APB: 80000200 - 80000300
>> gptimer0 Aeroflex Gaisler Modular Timer Unit
>> APB: 80000300 - 80000400
>> IRQ: 8
>> 8-bit scalar, 2 * 32-bit timers, divisor 50
>> uart1 Aeroflex Gaisler Generic UART
>> APB: 80000900 - 80000A00
IRQ: 3
>> Baudrate 38343
>> gpio0 Aeroflex Gaisler General Purpose I/O port
>> APB: 80000B00 - 80000C00
>>I have wrote a testing app to check if both UARTs work and also to try to install a handler for RX on the second UART. Here is my code:
>>#include <rtems.h>
>>rtems_task Init( rtems_task_argument argument); /* forward declaration needed */
>>/* configuration information */
>>#define CONFIGURE_INIT
>>#include <bsp.h> /* for device driver prototypes
>>#define
CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>#define
CONFIGURE_MAXIMUM_TASKS 4
>>#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>#include <rtems/confdefs.h>
>>#include <stdio.h>
>>#include <stdlib.h>
>>#include <sys/types.h>
>>#include <sys/stat.h>
>>#include <unistd.h>
>>#include <errno.h>
>>#include <apbuart.h>
>>// Global Variable to check if Interrupt has been signaled.
>>unsigned char uc_intr_flag;
>>// Interrupt handler for APBUART peripheral
>>void UARTInterruptHandler ()
>> uc_intr_flag = 1;
>>rtems_task Init (rtems_task_argument ignored)
>> int i;
>> rtems_status_code ret_status;
>> rtems_isr_entry old_handler;
>> volatile int *apbuart1 =
(int*)0x80000900;
>> volatile int aux;
>> // Reset Interrupt Flag
>> uc_intr_flag = 0;
>> printf("APB UART TEST with Interrupts\n");
>> aux = apbuart1[1];
>> printf("APBUART1 STATUS: 0x%08X\n", aux);
>> aux = apbuart1[2];
>> printf("APBUART1 CONTROL: 0x%08X\n", aux);
>> // Install UARTInterruptHandler at vector number 3
>> ret_status = rtems_interrupt_catch(
>> &old_handler);
>> switch (ret_status)
case RTEMS_SUCCESSFUL :
>> printf("rtems_interrupt_catch: OK. New Interrupt installed for IRQ 3 - APBUART 2.\n");
>> break ;
>> case RTEMS_INVALID_NUMBER :
>> printf("rtems_interrupt_catch: RTEMS_INVALID_NUMBER.\n");
>> break ;
>> case RTEMS_INVALID_ADDRESS :
>> printf("rtems_interrupt_catch: RTEMS_INVALID_ADDRESS.\n");
break ;
>> default
>> printf("rtems_interrupt_catch: Unknown error.\n");
>> break ;
>> // Tell uart hardware to initialize directly
>> /* Enable receiver (with interrupts) & Transmitter */
>> apbuart1[2] = APBUART_CTRL_RE | APBUART_CTRL_TE | APBUART_CTRL_RI;
>> aux = apbuart1[1];
>> printf("UART1 STATUS: 0x%02X\n", aux);
>> aux = apbuart1[2];
>> printf("UART1 CONTROL: 0x%08X\n", aux);
>> // Write a character though APBUART1 to test it
>> apbuart1[0] =
0xD8;
>> while (1)
>> { // Perform some active wait time
>> for (i
= 2000000; i > 0; i--);
>> printf("Hello World\n");
>> apbuart1[0] = 0xD8;
>> // If interrupt received, read from APBUART
>> if (uc_intr_flag == 1)
>> uc_intr_flag = 0;
>> aux = apbuart1[0];
>> printf("Interrupt received from UART: data = %X\n", aux);
>> exit (0);
>>First UART (ie. debug UART) works fine and output data through STDOUT
properly. Data sent through second UART is received also by another
external terminal, and in other test I have been capable of receiving
too. However UARTInterruptHandler is never signaled, thus I guess I am
missing something with the interrupt instalation.
>>Could any one see anything missing in this code? I would very much appreciate some help. Any clue on how to properly use interrupts will help me a lot!
>>Thanks!
>>Alberto.
>>_______________________________________________
>>rtems-users mailing list
>>http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140407/4521deda/attachment-0001.html>
