How to porting Nano-X to RTEMS, graphic drivers support and PC VESA support.
黄喜 huangxi_hans at 163.com
Tue Apr 15 01:01:54 UTC 2014
Hi  Pavel,
        I'm  very happy to get your mail. May be Nano-x can't support the VGA device  from your mail. But has a method can realize it. I know the SM502 graphic MCU support LVDS and VGA graphic port. So we can through write the framebuffer,and the SM502 can convert the pixel to VGA format.
         Through your attaching file. Maybe I can porting the Nano-X with RTEMS to ARM MCU with a LCD.
              Best Wishes.
                                           Hans
At 2014-04-14 20:48:33,"Pavel Pisa" <pisa at cmp.felk.cvut.cz> wrote:
>Hello all,
>On Sunday 13 of April 2014 06:13:59 Aaron J. Grier wrote:
>> there was some work done on the toolkit in 2012:
>> http://www.rtems.org/wiki/index.php/RTEMSGraphicsToolkit#Experimental_GSoC_
>>2012_Version_of_the_RTEMS_Graphics_Toolkit you should be able to leverage
>> this for your ARM project.
>> I'm a bit out of touch with the current activities involving RTEMS and
>> Nano-X.  The last project I worked on with RTEMS and Nano-X was
>> discontinued at the end of 2010.
>we are using Microwindows/Nano-X codebase together
>with our SuiTk GUI on RTEMS at company on ARM CSB336
>board.
>We have tested actual RTEMS git build for i386
>with Nano-X under QEMU with CIRRUS GD5446 driver
>developed during mentioned GSoC. The RTEMS configuration
>for that setup is described there
>http://www.rtems.org/wiki/index.php/RTEMSGraphicsToolkit#Running_RTEMS_Graphics_Toolkit_under_QEMU
>The use of Nano-X with RTEMS on embedded targets where
>framebuffer is simply mapped from fixed someaddress
>in fixed format is quite straightforward. I can provide
>some info and code which we use. I am attaching microwin-080121
>version of our adapted driver as example.
>When it is put into src/drivers directory and Nano-X are modified
>to build an use that "driver"/configuration then it can be
>used from application. I.e. calling GdOpenScreen() low level init.
>But such solution is not usable for PC and even on other targets
>it is bypassing RTEMS drivers framework.
>One of our students - Jan Dolezal - is working now on VESA BIOS
>Extension (VBE3) based solution for standard PC hardware.
>It should be integrated same as CIRRUS GD5446 driver into RTEMS
>mainline if he succeed. Unfortuantelly QEMU VESA BIOS does not
>provide VBE3 support but our initial check shows that most f real cards
>support it. So we hope to provide that solution and then next step
>is add layer to switch between three i386 (VGA, Cirrus and VBE3)
>graphic divers during startup phase. Problem is, that VGA is unusable
>with actual Nano-X because actual Nano-X deprecated/removes old
>planes based driver for ancient VGA hardware.
>The support for VBE3 requires application/driver configurable GDT
>entries. Jan Dolezal has already setup GIT repository with his work
>  https://github.com/dolezaljan/rtems
>As for Nano-X build with use of do_it script, we have found some problem
>with actual version in
>  git://git.rtems.org/rtems-graphics-toolkit.git
>The repo points to incorrect Nano-X GIT revision.
>We have used last Alexandru-Sever Horin's version.
>  git://github.com/alex-sever-h/microwin.git
>and have some minor patch for config. Jan Jan Dolezal should prepare
>it during his bachelor thesis. All is work in progress and we
>planned to announce our actual steps when we have more finished,
>but I am sending as much info now when there is and interrest
>to coordinate possible effort of others and do not repeat
>fails and looking for same corrections.
>Best wishes
>                Pavel Pisa
>    e-mail:     pisa at cmp.felk.cvut.cz
>    www:        http://cmp.felk.cvut.cz/~pisa
>    university: http://dce.fel.cvut.cz/
>    company:    http://www.pikron.com/
URL: <http://lists.rtems.org/pipermail/users/attachments/20140415/9e29396b/attachment-0001.html>
