toolchain versions (was Re: compile error in dwmac-desc-enh.c)
Fri Aug 8 23:19:42 UTC 2014
On 9/08/2014 12:00 am, Gedare Bloom wrote:
> On Thu, Aug 7, 2014 at 9:22 PM, Chris Johns <chrisj at rtems.org> wrote:
>> On 8/08/2014 6:49 am, Joel Sherrill wrote:
>> Back to the point on rtems-tools being the master. It is as well as
>> references to suitable web sites that host and provide support for the
>> upstream project. For example the NIOS2 patch being used by the RSB is
>> http://patchwork.ozlabs.org/patch/364504/. The RSB references this patch
>> directly
>> http://git.rtems.org/rtems-source-builder/tree/rtems/config/4.11/rtems-nios2.bset#n19.
> Perhaps there should be a generic config file in rtems-tools that
> provides links to these external patches?
Yes we do need something. I will look at some form of INI file format.
Plenty of bits of code around to parse this format.
> RSB would then parse tha config file.
I wish it was that simple. I will look at a way to check against such a
file.
> It would make it easier for other packagers to be sure
> they are building the right toolchain. This will separate the policy
> of deciding what should go into a toolchain (versions, patches, etc)
> from the mechanism that builds it, e.g. RSB or some other packager.
I agree.
