rtems source builde git repository
Hoefle Marco
Marco.Hoefle at nanotronic.ch
Wed Aug 13 17:38:02 UTC 2014
Hello Chris,
fetching tar files works now but our rtems git tree not:
hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems$ ../source-builder/sb-set-builder --log=$TOOLCHAIN_DIR/4.10-sparc.log --prefix=$TOOLCHAIN_DIR --no-clean 4.10/rtems-sparc-gr.bset
RTEMS Source Builder - Set Builder, v0.4.0
Build Set: 4.10/rtems-sparc-gr.bset
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-linux-gnu-1
building: expat-2.1.0-x86_64-linux-gnu-1
config: tools/rtems-binutils-2.20.1-1.cfg
package: sparc-rtems4.10-binutils-2.20.1-1
warning: binutils-2.20.1.tar.bz2: no hash found
warning: binutils-2.20.1-rtems4.10-20100826.diff: no hash found
building: sparc-rtems4.10-binutils-2.20.1-1
config: tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg
package: sparc-rtems4.10-gcc-4.4.7-newlib-1.18.0-1
warning: gcc-core-4.4.7.tar.bz2: no hash found
warning: gcc-core-4.4.7-rtems4.10-20120314.diff: no hash found
warning: newlib-1.18.0.tar.gz: no hash found
warning: newlib-1.18.0-rtems4.10-20110518.diff: no hash found
warning: mpfr-2.4.2.tar.bz2: no hash found
warning: mpc-0.8.1.tar.gz: no hash found
warning: gmp-5.0.5.tar.bz2: no hash found
building: sparc-rtems4.10-gcc-4.4.7-newlib-1.18.0-1
config: tools/rtems-gdb-7.3.1-1.cfg
package: sparc-rtems4.10-gdb-7.3.1-1
warning: gdb-7.3.1.tar.bz2: no hash found
warning: gdb-7.3.1-rtems4.10-20120918.diff: no hash found
building: sparc-rtems4.10-gdb-7.3.1-1
config: tools/rtems-kernel-4.10-1.2.14-gr.cfg
package: sparc-rtems4.10-kernel-4.10-1
error: malforned URL: git.nanotronic:rtems.git?reset=hard?pull?branch=gr-4.10
Build FAILED
See error report: rsb-report-sparc-rtems4.10-kernel-4.10-1.txt
Build Set: Time 0:05:48.729840
Build FAILED
This is how the rtems source was set up:
%source set rtems git.nanotronic:rtems.git?reset=hard?pull?branch=gr-4.10
Does rtems-source-builder still work with a git repository via ssh?
Thanks,
Marco
-----Original Message-----
Sent: Tue 12/08/2014 05:05
To: Hoefle Marco; users at rtems.org
Subject: Re: rtems source builde git repository
On 12/08/2014 8:14 am, Chris Johns wrote:
> On 11/08/2014 8:17 pm, Hoefle Marco wrote:
>> However I wanted to have a look how the other builds are working. Thus I
>> checked out the latest commit from 2014-08-09
>> sb: Add INI format output to the reports.
>> The INI format report is a way to export a configuration.
>> There I wanted to build the normal sparc toolchain + rtems Kernel before
>> I proceed with our gaisler patched rtems git tree:
> Ouch. I have broken something while adding INI file support. I will take
> a look and fix this. Sorry about this.
I have fixed this issue so please update and try again.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140813/345f48dc/attachment.html>
