Samples not built in the VM image
David Shifflett shifflett at nps.edu
Mon Aug 18 16:00:13 UTC 2014
Joel,
No this is not resolved.
I still need to figure out what needs to be updated
in order to get the build to complete successfully.
I suspect it is newlib, but maybe more as well.
How do I update newlib?
dave
On 8/16/14 2:40 PM, Joel Sherrill wrote:
> Any luck since then? I thought this was resolved by having me tools
> On August 12, 2014 3:57:35 PM CDT, David Shifflett <shifflett at nps.edu> wrote:
>> It appears that the builds did NOT succeed.
>> I apologize, I didn't carefully review the b.log files.
>> For each CPU there was a failure in building
>> rtems/c/src/libchip/network/dwmac-desc-enh.c related to __DEVOLATILE
>> It appears that this isn't defined, or the definition isn't found.
>> I see in other posts that this might be related to the version of
>> newlib
>> installed in the VM.
>> i386-rtems4.11-gcc --version shows
>> i386-rtems4.11-gcc (GCC) 4.8.2 20131016 (RTEMS
>> gcc-4.8.2-4.el6/newlib-1.20.0-30el6)
>> That other thread talked a lot about patching newlib,
>> can I just update to newlib-2.1.0?
>> dave
>> On 8/12/14 12:31 PM, Joel Sherrill wrote:
>>> On 8/12/2014 2:03 PM, David Shifflett wrote:
>>>> On 8/12/14 11:21 AM, Joel Sherrill wrote:
>>>>> On 8/12/2014 1:03 PM, David Shifflett wrote:
>>>>>> Hi,
>>>>>> I am new to RTEMS.
>>>>>> I downloaded the VM image,
>>>>>> and ran all the steps to update the OS, etc
>>>>>> also pulled the latest from GIT and ran the bootstrap,
>>>>>> all with no problems.
>>>>> That is good to hear. Last time I tried to cut a VM image it
>> increased
>>>>> massively in size. :(
>>>>>> Finally I ran the suggested two build_bsp commands.
>>>>> Does this have "--enable-tests=samples" on the configure command?
>>>> Yes the helper script build_bsp has "--enable-tests=samples"
>>> Did the build succeed? Check b-<BSP>/b.log and b-<BSP>/c.log
>>> After the build passes, there should be about a dozen sample .ralf's
>>>>>> After this I could only find two applications, 1 for sparc and 1
>> for
>>>>>> i386, specifically
>>>>>> 'network-demos/netdemo/o-optimize/netdemo.ralf' (and '.exe').
>>>>> Those are leftover from a previous unrelated build.
>>>>>> Looking at the times on these files suggests they weren't recently
>>>>>> built, but included in the VM image.
>>>>>> How do I build the other sample applications?
>>>>> The examples in examples-v2 can be built using waf or by exporting
>>>>> RTEMS_MAKEFILE_PATH with the appropriate value. It would be
>>>>> something like ${prefix}/${target}/${bsp} where those get replaced
>>>>> with real values.
>>>> You've lost me here.
>>>> The VM has no examples-v2.
>>>> Is that something I should separately download?
>>> It is in a separate git repo on git.rtems.org so a git clone is
>> needed
>>> if it isn't on there.
>>>> Also, I've never used waf, is that included on the VM image,
>>>> or will I need to install it separately?
>>> I would just use the make technique
>>>> What about building the code in
>>>> b-sis/sparc-rtems4.11/c/sis/testsuites/samples or
>>>> b-pc386/i386-rtems4.11/c/pc386/testsuites/samples?
>>>> I tried running 'make all' in those directories,
>>>> but got 'cannot find -lrtemsbsp'.
>>>> When was this library supposed to be created?
>>>> I couldn't find it anywhere.
>>>> Maybe my bootstrap did have some problems that I didn't see.
>>>> What is the best way to verify the environment and tools?
>>> Look at the log files I mentioned above. Something failed.
>>> Is your PATH correct?
>>>> Thanks again for your help,
>>>> dave
>>>>>> TIA,
>>>>>> dave
>>>>>> _______________________________________________
>>>>>> users mailing list
>>>>>> users at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/users
