rtems source builde git repository
Hoefle Marco Marco.Hoefle at nanotronic.ch
Mon Aug 25 08:26:03 UTC 2014
Hello Chris,
I just tried the latest commit from 23.08.
Unfortunately it still fails with
error: malforned URL: git.nanotronic:rtems.git?reset=hard?pull?branch=gr-4.10
Build FAILED
  See error report: rsb-report-sparc-rtems4.10-kernel-4.10-1.txt
Build Set: Time 0:05:35.003275
Build FAILED
We use gitolite as our repository management tool and thus we set our ssh config file as:
hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems$ cat ~/.ssh/config
Host git.nanotronic
HostName srv03
User gitolite
IdentityFile ~/.ssh/id_dsa-git
Cloning from command line and with a previous version of source builder works.
regards,
Marco
-----Original Message-----
Sent: Tue 19/08/2014 14:46
To: Hoefle Marco; users at rtems.org
Subject: Re: rtems source builde git repository
On 19/08/2014 10:20 pm, Hoefle Marco wrote:
> Dear Chris,
> cloning rtems using git works (and worked also with the previous rtems
> source builder version):
I fixed some of the download code and this may now catch the URL.
> hoefle at wheezy:/tmp/hoefle$ git clone git.nanotronic:rtems.git
> Cloning into 'rtems'...
> remote: Counting objects: 452048, done.
> remote: Compressing objects: 100% (76658/76658), done.
> remote: Total 452048 (delta 366194), reused 451708 (delta 365854)
> Receiving objects: 100% (452048/452048), 62.37 MiB | 29.90 MiB/s, done.
> Resolving deltas: 100% (366194/366194), done.
> this is the content of:
> ./rtems-source-builder/rtems/rsb-report-sparc-rtems4.10-kernel-4.10-1.txt
> hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test$
> cat
> RTEMS Tools Project - Source Builder Error Report
>   Build: error: malforned URL:
Following this ...
http://www.rtems.org/ftp/pub/rtems/people/chrisj/source-builder/source-builder.html#_git
I would try:
  git://git.nanotronic:rtems.git?reset=hard?pull?branch=gr-4.10
as the URL the RSB config file.
Please update the RSB as I just fixed a bug Joel and Josh pointed out.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140825/28758169/attachment-0002.html>
