CVS access failures
Federico Casares
federico.casares at tallertechnologies.com
Thu Aug 28 17:46:42 UTC 2014
Same error happens to me yesterday... IT block :P
regards
On Thu, Aug 28, 2014 at 2:44 PM, Shifflett, David (CIV) <shifflett at nps.edu>
wrote:
> I am trying to build on a Fedora 19 system.
> I am getting a 'connection refused' error when it tries to checkout
> newlib from sourceware.org
> It is possible that CVS is being blocked by my IT department,
> I am looking into that.
> Can someone confirm that the CVS server at sourceware.org
> is up and accessible?
> If CVS access is being blocked,
> what alternatives do I have for getting things built?
> Build command:
> ../source-builder/sb-set-builder --log=l-sparc.txt
> --prefix=$HOME/development/rtems/4.11 4.11/rtems-sparc
> Tail of error log:
> script: 84: cd ${build_top}
> script: 85: source_dir_newlib="newlib-19-Aug-2014"
> source setup: sparc-rtems4.11-gcc-4.8.3-newlib-19-Aug-2014-1: source
> newlib -q -D -n newlib-19-Aug-2014
> Creating source directory: sources/cvs
> making dir:
> /home/user/development/rtems/src/rtems-source-builder/rtems/sources/cvs
> sources/cvs/anoncvs_sourceware_org_cvs_src_newlib_19_Aug_2014
> cvs: checkout: cvs://pserver:anoncvs@sourceware.org/cvs/src ->
> cmd:
> (/home/user/development/rtems/src/rtems-source-builder/rtems/sources/cvs/anoncvs_sourceware_org_cvs_src_newlib_19_Aug_2014)
> /usr/bin/cvs -z 9 -q -d :pserver:anoncvs at sourceware.org/cvs/src co -N -D
> 19-Aug-2014 newlib
> cvs [checkout aborted]: connect to [sourceware.org]:2401 failed:
> Connection refused
> error: cvs command failed (['/usr/bin/cvs', '-z', '9', '-q', '-d', ':
> pserver:anoncvs at sourceware.org/cvs/src', 'co', '-N', '-D', '19-Aug-2014',
> 'newlib']): 1
> I also tried to access CVS from the command line
> and got the same 'connection refused' error.
> THanks for any help,
> dave
> users mailing list
> users at rtems.org
[image: http://www.tallertechnologies.com]
<http://www.tallertechnologies.com>
Casares, Federico
Sr. Software Engineer
Taller Technologies Argentina
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
URL: <http://lists.rtems.org/pipermail/users/attachments/20140828/a2e2ee1b/attachment-0002.html>
