Removing module
Gedare Bloom
gedare at rtems.org
Thu Dec 4 16:11:43 UTC 2014
Reine,
I found your message on the build ml that is better sent to the users
mailing list, so I transcribed it here.
With the master branch of RTEMS I don't believe setting MANAGERS makes
a difference. Unused code is no longer linked into the application
executable. What version of RTEMS are you using?
If you look in the testsuites/ directory you can find many examples,
and searching for "MANAGERS" in the Makefiles can show you how to use
the option in the older RTEMS releases.
-Gedare
On Thu, Dec 4, 2014 at 11:09 AM, Gedare Bloom <gedare at gwu.edu> wrote:
> Hello
> It says in the RTEMS documentation that some managers are optional.
> I tried to remove the region manager from the kernel by modifying the
> file make/leaf.cfg see excerpt of top of file below:
> # make/leaf.cfg
> # Make(1) configuration file include'd by all leaf-node Makefiles
> # list of all known managers
> # This list is used, along with $(MANAGERS) (set by app makefile)
> # to build the list of *not wanted* drivers.
> # ref: target compiler config file for usage
> #MANAGER_LIST=barrier dpmem event io msg mp part
> #MANAGER_LIST+=region sem signal timer rtmon ext
> MANAGER_LIST+=sem signal timer rtmon ext
> Then I compiled as usual including a bootstrap.
> However it did not seem to change anything?
> (The region symbols are still in the librtemscpu.a library)
> What am I doing wrong ? should is set MANAGERS somewhere ?
> Best regards
> Reine Gill
