Signal handler in RTEMS
Ben Dart
Ben.Dart at adept.com
Wed Dec 31 21:32:50 UTC 2014
void HandleAndPrintSignal()
printf("I am in the segfault signal handler AND I WILL HANDLE YOUR SIG!!!!\n");
while(1){ printf("LALALA\n"); }
exit(1);
void *POSIX_Init(void *args)
printf("BENS BIG NOTE: Initializing Signal Handler\n");
struct sigaction sa;
sa.sa_handler = HandleAndPrintSignal;
sigemptyset(&sa.sa_mask);
sa.sa_flags = SA_SIGINFO;
if (sigaction (SIGSEGV, &sa, 0)) {
printf("A ERROR OCCURED WITH THIS!");
exit(1);
int *p = NULL;
while(1)
printf("Doing some looping\n");
*(p--) = 5;
printf("%d", *p);
This will cause a seg fault as expected. However instead of being caught by the signal handler a kernel routine under vectors_init.c will print the following stack trace:
Exception handler called for exception 12 (0xC)
Next PC or Address of fault = 003506BC
Saved MSR = 00003012
Context: Task ID 0x0B010001
R0 = 003506B8 R1 = 06827C58 R2 = 004A54F8 R3 = 00000000
R4 = 06827BE8 R5 = 00000013 R6 = 06827C84 R7 = 00000001
R8 = 00000000 R9 = 00000800 R10 = F0002000 R11 = F0002000
R12 = 25555582 R13 = 0051A7C0 R14 = 55555555 R15 = 55555555
R16 = 55555555 R17 = 55555555 R18 = 55555555 R19 = 55555555
R20 = 55555555 R21 = 55555555 R22 = 06827F10 R23 = 00000001
R24 = 06827D78 R25 = 003CD20C R26 = 06827D94 R27 = 00000000
R28 = 006FF698 R29 = 00000013 R30 = 00000000 R31 = 1A01000E
CR = 45555582
CTR = 00350EB0
XER = 00000000
LR = 003506B8
DAR = 00000000
Stack Trace:
IP: 0x003506BC, LR: 0x003506B8
--^ 0x0038C364--^ 0x00389AF0--^ 0x0036BC5C--^ 0x00350F70--^ 0x0038AD78
--^ 0x0036071C--^ 0x0036D330--^ 0x0036D3B0--^ 0x0033E514--^ 0x003399D0
--^ 0x0033B4F0--^ 0x0033D80C--^ 0x0019B68C--^ 0x003C6934--^ 0x003C6850
Suspending faulting task (0x0B010001)
Is there something special that needs to be done to set up signal handlers for RTEMS? It seems like from this manual:
http://docs.rtems.org/doc-current/share/rtems/pdf/posix1003_1.pdf <http://docs.rtems.org/doc-current/share/rtems/pdf/posix1003_1.pdf%20under%20section%203.3.1.1>
under section 3.3.1.1 indicates that signals have been implemented.
Is there something that I am doing wrong?
URL: <http://lists.rtems.org/pipermail/users/attachments/20141231/354cc710/attachment-0001.html>
