Overriding linkcmds?
James Fitzsimons
james.fitzsimons at gmail.com
Fri Feb 7 06:46:59 UTC 2014
Hi all,
I can report that using CFLAGS_FOR_TARGET worked. e.g
CFLAGS_FOR_TARGET+=-qnolinkcmds -T $(exec_prefix)/mrm332/lib/linkcmds_ROM
Will now use the ROM linker script instead of the RAM linker script which
has the default name linkcmds
Cheers,
James
On 7 February 2014 10:03, James Fitzsimons <james.fitzsimons at gmail.com>wrote:
> Thanks for your replies guys,
> Sebastian - I'll see if I can figure out how to work that into my
> makefile. I suppose I could try using the CFLAGS_FOR_TARGET again like I
> did with the header include path....
> Peter - I'm targeting a M68332 (specifically the mrm332 bsp). Ideally I'd
> like a simple makefile switch I can turn on or off to target RAM or ROM,
> but if it's too difficult I'll just cheat and rename my linker scripts
> depending on where I want to load my code to.
> Cheers,
> James Fitzsimons
> On 7 February 2014 00:41, Peter Dufault <dufault at hda.com> wrote:
>> What target are you using? On the MPC5554 I use the MMU to swap the
>> flash and the RAM so it winds up being the same image. Of course it means
>> my development system needs to be loaded with RAM.
>> On Feb 6, 2014, at 04:37 , James Fitzsimons <james.fitzsimons at gmail.com>
>> wrote:
>> Hi all,
>> I'm slowly trying to figure out the RTEMS build process and how to bend
>> it to my will!
>> I have two linker scripts, one for running out of RAM, and one for
>> running out of ROM.
>> Is there anyway to override which linker file will be used in your
>> makefile?
>> I found the following in my gcc-target-default.cfg
>> # Allow user to override link commands (to build a prom image, perhaps)
>> ifndef LINKCMDS
>> LINKCMDS=$(PROJECT_RELEASE)/lib/linkcmds
>> endif
>> But overriding LINKCMDS and specifying a different linker script in my
>> makefile didn't work.
>> Any advice would be gratefully received.
>> Thanks and regards,
>> James Fitzsimons
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
>> Peter
>> Peter Dufault
>> HD Associates, Inc. Software and System Engineering
URL: <http://lists.rtems.org/pipermail/users/attachments/20140207/e1b01889/attachment.html>
