Overriding linkcmds?
Fri Feb 7 14:58:35 UTC 2014
Thanks for the report. I wonder if there is an easy way to put an
example of this custom linkscript in the examples-v2 repository.
Possibly not, considering the linkscript is hardware-dependent.
-Gedare
On Fri, Feb 7, 2014 at 1:46 AM, James Fitzsimons
<james.fitzsimons at gmail.com> wrote:
> Hi all,
> I can report that using CFLAGS_FOR_TARGET worked. e.g
> CFLAGS_FOR_TARGET+=-qnolinkcmds -T $(exec_prefix)/mrm332/lib/linkcmds_ROM
> Will now use the ROM linker script instead of the RAM linker script which
> has the default name linkcmds
> Cheers,
> James
> On 7 February 2014 10:03, James Fitzsimons <james.fitzsimons at gmail.com>
> wrote:
>> Thanks for your replies guys,
>> Sebastian - I'll see if I can figure out how to work that into my
>> makefile. I suppose I could try using the CFLAGS_FOR_TARGET again like I did
>> with the header include path....
>> Peter - I'm targeting a M68332 (specifically the mrm332 bsp). Ideally I'd
>> like a simple makefile switch I can turn on or off to target RAM or ROM, but
>> if it's too difficult I'll just cheat and rename my linker scripts depending
>> on where I want to load my code to.
>> Cheers,
>> James Fitzsimons
>> On 7 February 2014 00:41, Peter Dufault <dufault at hda.com> wrote:
>>> What target are you using?  On the MPC5554 I use the MMU to swap the
>>> flash and the RAM so it winds up being the same image.  Of course it means
>>> my development system needs to be loaded with RAM.
>>> On Feb 6, 2014, at 04:37 , James Fitzsimons <james.fitzsimons at gmail.com>
>>> wrote:
>>> Hi all,
>>> I'm slowly trying to figure out the RTEMS build process and how to bend
>>> it to my will!
>>> I have two linker scripts, one for running out of RAM, and one for
>>> running out of ROM.
>>> Is there anyway to override which linker file will be used in your
>>> makefile?
>>> I found the following in my gcc-target-default.cfg
>>> # Allow user to override link commands (to build a prom image, perhaps)
>>> ifndef LINKCMDS
>>> LINKCMDS=$(PROJECT_RELEASE)/lib/linkcmds
>>> endif
>>> But overriding LINKCMDS and specifying a different linker script in my
>>> makefile didn't work.
>>> Any advice would be gratefully received.
>>> Thanks and regards,
>>> James Fitzsimons
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>> Peter
>>> Peter Dufault
>>> HD Associates, Inc.      Software and System Engineering
