RAW UART
Nicolás Alvarez
nicoalar.22 at gmail.com
Thu Feb 20 16:28:34 UTC 2014
Thanks Joel, finally we are using the console driver, setting the uart in
non-canonical mode with termios. It´s working great.
Regards,
*Ing. Nicolás Alvarez*
cel: 03548-15638454
http://ar.linkedin.com/in/ingalvarez/en
On Thu, Feb 20, 2014 at 1:15 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
> If you do that, you won't get the driver at all. Your code is correct and
> just reopening the device and changing the settings.
> The issue is what to do with stdin, out, and err if you reuse the physical
> device.
> On Dec 23, 2013 12:46 PM, Wendell Silva <silvawp at gmail.com> wrote:
> To avoid the console driver to be initialized by the BSP, I guess it
> is sufficient to remove the CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER from
> your "system.h".
> 2013/12/23 Nicolás Alvarez <nicoalar.22 at gmail.com>
>> Hi all,
>> I'm trying to use the raw uart driver interface, but it looks like that
>> the bsp is initializing the console driver. How can I avoid this? I have
>> read that someone use the console driver in "raw mode", is it the right way?
>> Regards,
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140220/9665471a/attachment.html>
