Downloading/Uploading RTEMS app to mcp750
Greg Menke
gregory.d.menke at nasa.gov
Wed Feb 19 16:51:52 UTC 2014
mcp750 has a rom monitor that can load and execute an rtems image via
tftp over ethernet- "nbo" command will do it. The output of the RTEMS
compilation will be an executable, that the mcp750 can load from a tftp
server. Very convenient. Once your app is in a more final state you
can put it in the flash or on a hard disk and the rom monitor will load
it from there- same exe format.
Greg
On 02/19/2014 11:28 AM, Noble N. Nkwocha wrote:
> Hi Joel,
> I do know that "RAD750 is ITARS" from your response to my earlier
> question several weeks ago. I am asking about mcp750. Is mcp750
> ITARS too, or is it synonymous with RAD750?
> Thank you,
> Noble N. Nkwocha
> (681) 753-5218 Work
> (304) 816-3718 Home
> (505) 238-5927 Cellular (Evenings, Nights and Weekends *_ONLY_*)
> Noble.N.Nkwocha at NASA.Gov <mailto:Noble.N.Nkwocha at nasa.gov>
> *From:*Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> *Sent:* Wednesday, February 19, 2014 11:15 AM
> *To:* Noble N. Nkwocha; rtems-users at rtems.org
> *Subject:* Re: Downloading/Uploading RTEMS app to mcp750
> The RAD750 is ITARS and there is no public documentation on it.
> My recollection is that we used the hardware debugger or downloaded
> via SuROM in its expected format.
> --joel
> On 2/19/2014 9:56 AM, Noble N. Nkwocha wrote:
> Hi everyone,
> 1.Is there a documented process for downloading / uploading an
> RTEMS .ralf / .exe image onto a PowerPC/mcp750 board?
> 2.If there is, would someone be kind enough to point us to it?
> Otherwise, could someone please help with how to?
> Thank you,
> Noble N. Nkwocha
> (681) 753-5218 Work
> (304) 816-3718 Home
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> rtems-users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20140219/74163912/attachment-0001.html>
