Downloading/Uploading RTEMS app to mcp750
Nick Withers
nick.withers at anu.edu.au
Wed Feb 19 23:14:32 UTC 2014
On Wed, 2014-02-19 at 11:56 -0500, Noble N. Nkwocha wrote:
> Thank you.
Don't suppose you could update the Wiki
( http://rtems.org/wiki/index.php/Mcp750 ) with this information for the
next person, could you?
More doco! :-P
Nick Withers
Embedded Systems Programmer
Department of Nuclear Physics, Research School of Physics and
Engineering
The Australian National University (CRICOS: 00120C)
> Noble N. Nkwocha
> (681) 753-5218 Work
> (304) 816-3718 Home
> (505) 238-5927 Cellular (Evenings, Nights and Weekends ONLY)
> Noble.N.Nkwocha at NASA.Gov
> From: Oyake, Amalaye (398K) [mailto:amalaye.oyake at jpl.nasa.gov]
> Sent: Wednesday, February 19, 2014 11:50 AM
> To: Noble N. Nkwocha; Joel Sherrill; rtems-users at rtems.org
> Subject: RE: Downloading/Uploading RTEMS app to mcp750
> Hello Noble,
> The MCP750 (the generic Motorola board that uses the PPC 750) should
> come with a bootloader. Connect it to a terminal program (Hyper
> Terminal is usually very straight forward), typically the settings are
> 9600-8-N-1 and then see what happens after a reset. Some of these
> boards have 1 or 2 serial ports, you just have to twiddle around to
> get the right one.
> Once you get the boot-loader going, you will see whether it is a
> VxWorks bootloader or Uboot or something else. I think you can get
> RTEMS loaded using the VxWorks bootloader (never tried it, but it
> seems "reasonable") ...
> The procedure is the same for any board - You have to find the
> bootloader (Uboot, GRUB, LILO or whatever it may be).
> The Stanford guys use some VME set up which should have similar
> procedures.
> Regards,
> * Amalaye Oyake *
> * Flight Software Applications & Data Product Mgmt */\
> * 818.393.7168 work 626.399.1707 cell *||
> * Jet Propulsion Laboratory, Pasadena CA 91109 */||\
> ______________________________________________________________________
> From: rtems-users-bounces at rtems.org [rtems-users-bounces at rtems.org] on
> behalf of Noble N. Nkwocha [Noble.N.Nkwocha at nasa.gov]
> Sent: Wednesday, February 19, 2014 8:28 AM
> To: Joel Sherrill; rtems-users at rtems.org
> Hi Joel,
> I do know that ?RAD750 is ITARS? from your response to my earlier
> question several weeks ago. I am asking about mcp750. Is mcp750
> ITARS too, or is it synonymous with RAD750?
> Thank you,
> Noble N. Nkwocha
> (681) 753-5218 Work
> (304) 816-3718 Home
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: Wednesday, February 19, 2014 11:15 AM
> To: Noble N. Nkwocha; rtems-users at rtems.org
> Subject: Re: Downloading/Uploading RTEMS app to mcp750
> The RAD750 is ITARS and there is no public documentation on it.
> My recollection is that we used the hardware debugger or downloaded
> via SuROM in its expected format.
> --joel
> On 2/19/2014 9:56 AM, Noble N. Nkwocha wrote:
> Hi everyone,
> 1. Is there a documented process for downloading /
> uploading an RTEMS .ralf / .exe image onto a PowerPC/mcp750
> board?
> 2. If there is, would someone be kind enough to point us
> to it? Otherwise, could someone please help with how to?
> Thank you,
> Noble N. Nkwocha
> (681) 753-5218 Work
> (304) 816-3718 Home
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> rtems-users mailing list
