had issues with loopback on the stm32f4
Peter Giguere
pgiguere at brightlogic.com
Mon Jan 13 07:26:42 UTC 2014
Hi All,
It looks like I sent the two messages below to the wrong address...
In summary, I am experiencing some issues using the stm32f4 bsp: the loopback test failed, and the fstests did not 'make'. See below for details.
Thanks,
Peter
----- Forwarded Message -----
From: "Peter Giguere" <pgiguere at brightlogic.com>
To: rtems-users-request at rtems.org
Sent: Monday, January 13, 2014 2:17:37 AM
Subject: had issues with loopback on the stm32f4
Further greetings!
I (also - see below) experienced some issues with the loopback sample code. Namely, with the code courtesy of git clone, no output at all.
However:
With
//#define CONFIGURE_EXECUTIVE_RAM_SIZE (512*1024)
and
#define CONFIGURE_MAXIMUM_TASKS 10//20
I do get output, albeit 'unexpected:'
"Network" initializing!
Can't get network cluster memory.
"Network" initialized!
Try running client with no server present.
Should fail with `connection refused'.
Can't create client socket: Unknown protocol
Start server.
Try running client with server present.
Create socket.
Try running two clients.
Can't create task: request not satisfied
fatal error, exiting
I neglected to say in the email below:
I am using the STM32F4 discovery +STF4BB base boards.
I edited the stm32f4 bsp configure.ac to disable all u(s)arts except for usart 6 (so only usart 6 is alive);
Otherwise, I followed the instructions from
http://alanstechnotes.blogspot.com/2013/03/setting-up-rtems-development.html
for the Raspberry Pi, except that I ran the configure script to enable-rtemsbsp=stm32f4, as described immediately below...
On the other hand, the hello world and ticker samples, for instance, ran perfectly well, as did the message queue sample.
Have I configured something correctly?
Regards,
Peter
----- Original Message -----
Sent: Sunday, January 12, 2014 2:42:07 PM
Subject: fstests failed to 'make' for the stm32f4 bsp
Greetings!
You might wish to know - fstests failed to 'make' for the stm32f4 bsp:
I ran configure (from within the target folder build-stm32f4) with the following settings:
../rtems-git/configure --target=arm-rtems4.11 \
--enable-rtemsbsp=stm32f4 \
--enable-tests=yes \
--enable-networking \
--enable-cxx \
--enable-posix \
--prefix=$HOME/development/rtems/bsps/4.11
followed by make. This resulted in the following error <as appears in the make output>:
Making all in fstests
make[4]: Entering directory `/home/peter/development/rtems/stm32f4-build/arm-rtems4.11/c/stm32f4/testsuites/fstests'
make all-recursive
make[5]: Entering directory `/home/peter/development/rtems/stm32f4-build/arm-rtems4.11/c/stm32f4/testsuites/fstests'
Making all in fsdosfsname01
make[6]: Entering directory `/home/peter/development/rtems/stm32f4-build/arm-rtems4.11/c/stm32f4/testsuites/fstests/fsdosfsname01'
old_path=
PATH=/home/peter/development/rtems/stlink:/home/peter/development/rtems/compiler/4.11/bin:/home/peter/development/rtems/compiler/4.11/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
arm-rtems4.11-gcc -B../../../../../stm32f4/lib/ -specs bsp_specs -qrtems -march=armv7-m -mthumb -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -march=armv7-m -mthumb -o fsdosfsname01.exe init.o ramdisk_support.o
linkcmds.base:400 cannot move location counter backwards (from 000000002002ea80 to 0000000020020000)
collect2: error: ld returned 1 exit status
make[6]: *** [fsdosfsname01.exe] Error 1
make[6]: Leaving directory `/home/peter/development/rtems/stm32f4-build/arm-rtems4.11/c/stm32f4/testsuites/fstests/fsdosfsname01'
make[5]: *** [all-recursive] Error 1
make[5]: Leaving directory `/home/peter/development/rtems/stm32f4-build/arm-rtems4.11/c/stm32f4/testsuites/fstests'
make[4]: *** [all] Error 2
make[4]: Leaving directory `/home/peter/development/rtems/stm32f4-build/arm-rtems4.11/c/stm32f4/testsuites/fstests'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/peter/development/rtems/stm32f4-build/arm-rtems4.11/c/stm32f4/testsuites'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/peter/development/rtems/stm32f4-build/arm-rtems4.11/c/stm32f4'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/peter/development/rtems/stm32f4-build/arm-rtems4.11/c'
make: *** [all-recursive] Error 1
Regards,
Peter
