MVME5500 1 Gbit Ethernet no longer works
Charlie Strohman crs5 at cornell.edu
Thu Jan 16 14:55:18 UTC 2014
I recently bought 2 new MVME5500 boards from Emerson. They have changed
the chip that supports the 1 Gbit ethernet interface from an Intel
82544EI to an Intel 82545GM. As a consequence, the 1 Gbit interface no
longer works, and the BSP issues the message:
    "i82544EI device ID not found"
Has anyone seen and fixed this? Might it be as simple as accepting the
PCI Device ID of the new chip? I'm using RTEMS 4.10.2. I looked at the
newest version and it seems to be the same code. I have not yet probed
into the hardware to see what ID value is being returned.
The ID of the older 82544EI is 0x1008 (from
"cpukit/include/rtems/pci.h), which according to the 410 page Software
Developer's Manual is the default value if the EEPROM is not programmed.
Thanks,
Charlie Strohman
231 Wilson Lab
Cornell University
Ithaca, NY 14853
607-255-0687
