Interested in contribute to RTEMS
Garvit Sharma
garvits45 at gmail.com
Wed Jan 22 17:45:04 UTC 2014
yes, I have got *.exe files, also *.ralf. I am using rtems4.10. I am using
fedora-19.
On Wed, Jan 22, 2014 at 11:12 PM, Gedare Bloom <gedare at rtems.org> wrote:
> I think you should also have gotten *.exe files for that target? What
> version of RTEMS are you using?
> The instructions at http://wiki.rtems.org/wiki/index.php/Qemu describe
> how to use Qemu with RTEMS especially on the i386. That is a good
> simulator to use and work with, as it also works for a lot of other
> RTEMS targets.
> -G
> On Wed, Jan 22, 2014 at 12:07 PM, Garvit Sharma <garvits45 at gmail.com>
> wrote:
> > Hi, I have done with the following tasks :
> > 1. Installed GNU cross-compilation tools for RTEMS on my host system.
> > 2. Installed RTEMS OS for the target host.
> > 3. I have chosen the target as i386 and BSP as i386/pc686.
> > 4. I have build the examples and from that I got *.ralf files. I know
> these
> > files are executables which are to be run on target machine. But how to
> do
> > so ? Is not there any simulator for that ?
> > Thanks,
> > On Wed, Jan 22, 2014 at 9:00 PM, Gedare Bloom <gedare at rtems.org> wrote:
> >> Probably the easiest place to start is
> >> http://www.rtems.org/wiki/index.php/GSoC_Getting_Started
> >> You may like to build the tools using the RSB:
> >> http://www.rtems.org/wiki/index.php/RSB
> >> -Gedare
> >> On Wed, Jan 22, 2014 at 6:16 AM, Garvit Sharma <garvits45 at gmail.com>
> >> wrote:
> >> > Hi, I have installed cross-compiler toolsets and now it is the time to
> >> > build
> >> > rtems from the source. I want to know that for which target
> architecture
> >> > should I build rtems.
> >> > On Wed, Jan 22, 2014 at 11:50 AM, Nick Withers <
> nick.withers at anu.edu.au>
> >> > wrote:
> >> >> On Wed, 2014-01-22 at 11:41 +0530, Garvit Sharma wrote:
> >> >> > Hello All,
> >> >> > I am a newbie to the world of rtems and want to make contributions
> >> >> > towards rtems. I have experience with
> >> >> > C/SystemProgramming/DeviceDrivers and gnu tools like gdb, strace
> and
> >> >> > Oprofile. Please show me the direction to start from.
> >> >> Hi Garvit!
> >> >> (Humble user here)
> >> >> Glad to hear you want to contribute, that's awesome :-)
> >> >> Perhaps have a look at
> >> >> http://www.rtems.org/wiki/index.php/Contributing#How_can_I_help.3F ?
> >> >> It's got both coding and non-coding suggestions that might help.
> >> >> Looking forward to your contributions :-)
> >> >> Nick Withers
> >> >> Embedded Systems Programmer
> >> >> Department of Nuclear Physics, Research School of Physics and
> >> >> Engineering
> >> >> The Australian National University (CRICOS: 00120C)
> >> >> > Thanks,
> >> >> > Garvit Sharma
> >> >> > B.Tech | Computer Science and Engineering
> >> >> > UG Final year
> >> >> > LNM IIT, Jaipur
> >> >> > No Body is a Scholar by birth, its only hard work and strong
> >> >> > determination that makes him master.
> >> >> > _______________________________________________
> >> >> > rtems-users mailing list
> >> >> > rtems-users at rtems.org
> >> >> > http://www.rtems.org/mailman/listinfo/rtems-users
> >> > Garvit Sharma
> >> > UG Final year
> >> > LNM IIT, Jaipur
> >> > determination
> > Garvit Sharma
> > UG Final year
> > LNM IIT, Jaipur
> determination
Garvit Sharma
UG Final year
LNM IIT, Jaipur
*No Body is a Scholar by birth, its only hard work and strong determination
that makes him master.*
URL: <http://lists.rtems.org/pipermail/users/attachments/20140122/cdfc90be/attachment.html>
