RTEMS available tasks
Mon Jan 27 14:07:45 UTC 2014
On Mon, Jan 27, 2014 at 7:30 AM, Andre Marques
<andre.lousa.marques at gmail.com> wrote:
> On 01/27/14 08:00, Sebastian Huber wrote:
>> Hello Andre,
>> On 2014-01-26 01:31, Andre Marques wrote:
>>> Hello,
>>> I'm a CS undergraduate student and i've decided to do something RTEMS
>>> related
>>> for my final project.
>> this is nice.
>>> I already have a RTEMS build (4.11) working on my Gentoo system and
>>> played a
>>> bit with the EDF and RM schedulers (just launching some tasks and
>>> counting the
>>> deadline misses).
>> Which BSP do you use?  If you want to work with a simulator BSP, then you
>> should have a look at the arm/realview_pbx_a9_qemu BSP since it offers a
>> NULL pointer read and write protection.  Qemu is also a fast simulator which
>> provides support for GDB watch points.  This is quite handy for development
>> and test suite runs.
> I'm using the pc386 BSP using Qemu with the pc386 script provided on
> rtems_testing. Only today I tested GDB with Qemu, which I'm finding a bit
> tricky with the pc386 script because as soon as the program finishes It
> closes Qemu, so I can't connect to the gdb server. To solve that I used the
> instructions on the Wiki about Qemu (which seems to be a little outdated, so
> I needed to change some steps) and I can now load a program and connect to
> the gdb server, but I don't have the symbol table for any program. I can't
> recall enabling debugging during the rtems configure stage, but will that
> generate symbol tables for every compiled program? Can't I just generate a
> symbol table for a specific program?
If you don't mind could you update the wiki page with your notes? you
might also like to include sebastian's notes about using the realview,
if you go that route..
>>> As of right now i'm between semesters, and looking to fill this gap with
>>> some
>>> coding fun. In [1] there is a task for making the implementation of
>>> rename()
>>> POSIX conformant. If this task is still open I would like to start
>>> working on it.
>> Yes, this task is still open and it is a good start point.
>> I would start with a new test in
>> http://git.rtems.org/rtems/tree/testsuites/fstests/
>> which covers the POSIX rename() specification
>> http://pubs.opengroup.org/onlinepubs/9699919799/functions/rename.html
> In that case that's where I'm going to start. Any questions that I might
> have should I post them on the users list or somewhere else?
>>> I also went through the Google Code-In open tasks and found this bug
>>> [2][3],
>> Fixing this bug is a very boring task.  You have to install also the tool
>> chain for each RTEMS target and build all BSPs.
>>> which I could also work on, but if there's anything more interesting
>>> (possibly
>>> some small task related with scheduling) please let me know.
>>> [1] -
>>> https://wiki.rtems.org/wiki/index.php/Open_Projects#API_Layers_.28POSIX.2C_Classic.2C_SAPI.29
>>> [2] -
>>> http://www.google-melange.com/gci/task/view/google/gci2013/5227914052239360
>>> [3] - https://www.rtems.org/bugzilla/show_bug.cgi?id=1279
>>> Thanks for your time,
>>> Andre Marques.
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
