RTEMS Installation & Configuration
Wed Jan 15 17:48:44 UTC 2014
On 1/15/2014 11:29 AM, Gedare Bloom wrote:
> On Wed, Jan 15, 2014 at 11:13 AM, Noble N. Nkwocha
> <Noble.N.Nkwocha at nasa.gov <mailto:Noble.N.Nkwocha at nasa.gov>> wrote:
>     Hi everyone,
>     My name is Noble N. Nkwocha and I am new to and with RTEMS.
> Welcome!
>     I was successful “I believe”, in installing and Configuring RTEMS
>     4.10.2 for the i386 and PowerPC target processors.   I used the
>     pre-built tools and binary versions.    Would someone please help
>     with the following questions?
> Unless your project requires you to use 4.10, I would encourage you to
> use 4.11 (which is the current git master, but should be released soon
> officially). I personally have limited experience with 4.10.
>     1.       Where is the resulting RTEMS Kernel after a successful
>     configuration?   What is its filename?   Should I expect to have a
>     file named “i386-rtems4.10-run” and another one named
>     “powerpc-rtems4.10-run” after the successful build of RTEMS4.10.2?
> Those "run" files point to simulators for the respective targets to
> aid in running RTEMS applications. These are part of the "RTEMS
> Toolset" in the pre-built tools. The RTEMS Kernel is a set of
> libraries that you get after you successfully configure, make, and
> "install" RTEMS. Installing RTEMS on your development host machine
> gives you the libraries that your application will link against. (This
> should really all be explained somewhere...)
>     2.       Why is it that I cannot not get a successful RTEMS
>     configuration for “powerpc” and “rad750” as target and BSP options
>     respectively?   I get an error message indicating that a branch
>     for the BSP (rad750) was not found.   The same problem occurs when
>     I try “qemuprep” for a “powerpc” BSP.     The RTEMS Documentations
>     I have, state that both the “rad750” and “qemuprep” are included
>     in the standard RTEMS PowerPC BSPs distribution.   What am I not
>     doing correct, here?
> The rad750 is not in the public release of RTEMS due to ITAR. You
> should discuss this with other RTEMS users at your institution if they
> have it, or you should contact OAR Corp who I believe can handle the
> issue.
Yep. The RAD750 BSP is an ITAR controlled. We will have to discuss that
privately.
Which NASA center are you with?
Which document states that the RAD750 is included in the standard RTEMS
distribution?
That needs to be corrected. It can at most say "available and please
contact OAR".
> I do not know why qemuprep does not work. You might first like to try
> the "psim" BSP, which is the simplest simulated powerpc BSP. psim runs
> within the powerpc-rtems4.10-gdb, which is invoked by the
> powerpc-rtems4.10-run command. If you build RTEMS with psim you should
> be able to use powerpc-rtems4.10-run on any of the compiled testsuites
> applications, such as testsuites/samples/hello/hello.exe.
Gedare is right here. Starting with a simulator in gdb is almost always
the easiest way
to get started.
The rtems-testing git repo has a directory named sim-scripts which
provide a simple
interface for running these simulators. psim in particular takes a LOT
of arguments.
>     3.       Why do I get the System Error message below, each time I
>     try the following:
>     $i386-rtems4.10-gdb`find . -name  ticker.exe`
> This looks like your host development machine is not fully set up. Are
> you using cygwin? If you have access to any Linux machines, you might
> have an easier time to get started using one of them instead. Windows
> should work, but it can be finicky and is generally less supported by
> the RTEMS community.
> Can you descend to find ticker.exe yourself? It should be located in
> something like
> i386-rtems4.10/c/i386ex/testsuites/samples/ticker/ticker.exe in the
> build tree (or substitute powerpc/psim for i386/i386ex).
>     This the command I used for my configurations.  “powerpc” and
>     “psim” were substituted for the target and BSP for our successful
>     PowerPC configuration
>     *    ../rtems-4.10.2/configure --target=i386-rtems4.10
>     --enable-rtemsbsp=i386ex --enable-cxx --enable-tests=samples*
>     *    make all*
>     *    make install*
> These commands look right at a glance, especially using powerpc and
> psim should work for sure. I take it there were no errors during these
> commands? Based on the other issues that you reported, I suspect the
> host development machine does not have quite the right environment /
> tools installed.
>     Thank you,
>     Noble N. Nkwocha
>     (681) 753-5218 <tel:%28681%29%20753-5218> Work
>     (304) 816-3718 <tel:%28304%29%20816-3718> Home
>     (505) 238-5927 <tel:%28505%29%20238-5927> Cellular (Evenings,
>     Nights and Weekends *_ONLY_*)
>     Noble.N.Nkwocha at NASA.Gov <mailto:Noble.N.Nkwocha at nasa.gov>
>     _______________________________________________
>     rtems-users mailing list
>     rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>     http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140115/ac382579/attachment-0001.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20140115/ac382579/attachment-0001.png>
