Interested in contribute to RTEMS
Gedare Bloom
gedare at rtems.org
Fri Jan 24 18:01:24 UTC 2014
That looks about right, so I am not sure what is going wrong. I have
not used Qemu with pc386 like this in a few years. You could try
poking around in the GRUB shell, there are some basic commands
available you can use to try to set the root and boot manually.
Otherwise, I would suggest trying out the
rtems-testing.git/sim-scripts/pc386 script just to get something that
works and come back to debug later if needed.
Gedare
On Fri, Jan 24, 2014 at 12:46 PM, Garvit Sharma <garvits45 at gmail.com> wrote:
> I have done the following things :
>>> mke2fs hda.img
>>> mkdir /mount/mount_point
>>> mount -o loop hda.img /mount/mount_point
>>> cp rtems-grub.cfg /mount/mount_point
> Let me know whether or not I did correctly
> On Fri, Jan 24, 2014 at 10:12 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> I prefer if you can keep your questions on the mailing list. You may
>> get other answers there, and others may benefit from your questions.
>> -Gedare
>> On Fri, Jan 24, 2014 at 11:40 AM, Garvit Sharma <garvits45 at gmail.com>
>> wrote:
>> > I have placed the rtems-grub.cfg in the same folder but still it is
>> > showing
>> > me the grub shell
>> > On Fri, Jan 24, 2014 at 8:45 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> >> If you are following the instructions on our wiki, then you need to
>> >> have a rtems-grub.cfg located in your hda.img file. You might also
>> >> like to try the instructions related to the "rtems-testing.git"
>> >> module.
>> >> -Gedare
>> >> On Fri, Jan 24, 2014 at 10:05 AM, Garvit Sharma <garvits45 at gmail.com>
>> >> wrote:
>> >> > Hi, I am executing the following command on my system
>> >> >>> qemu-system-i386 -m 128 -boot a -fda rtems-boot.img -hda hda.img
>> >> >>> -hdb
>> >> >>> fat:. -serial stdio -no-reboot -s
>> >> > after that gui of qemu appeared and it consists of grub shell. I am
>> >> > not
>> >> > getting what to do next.
>> >> > On Wed, Jan 22, 2014 at 11:46 PM, Gedare Bloom <gedare at rtems.org>
>> >> > wrote:
>> >> >> You might like to consider going to the task list for Google Code-In
>> >> >> [1] and filter for "RTEMS" as the Organization field and "open" for
>> >> >> the Status field. These tasks are relatively easy to get started on
>> >> >> so
>> >> >> you can look for something that might interest you. There are some
>> >> >> possible bug fixes and some test case refactoring tasks.
>> >> >> [1] http://www.google-melange.com/gci/tasks/google/gci2013
>> >> >> On Wed, Jan 22, 2014 at 1:03 PM, Garvit Sharma <garvits45 at gmail.com>
>> >> >> wrote:
>> >> >> > I am configuring qemu to see examples working, In the meanwhile
>> >> >> > please
>> >> >> > tell
>> >> >> > me how should I make my first contribution to this organization.
>> >> >> > Which
>> >> >> > bug
>> >> >> > should I start with ?
>> >> >> > On Wed, Jan 22, 2014 at 11:21 PM, Gedare Bloom <gedare at rtems.org>
>> >> >> > wrote:
>> >> >> >> ok. for 4.10 i think it should "just work". For new development,
>> >> >> >> we
>> >> >> >> suggest using 4.11 (the current git master). We only accept bug
>> >> >> >> fixes
>> >> >> >> submitted to 4.10. Hopefully a 4.11 release will come soon!
>> >> >> >> -Gedare
>> >> >> >> On Wed, Jan 22, 2014 at 12:45 PM, Garvit Sharma
>> >> >> >> wrote:
>> >> >> >> > yes, I have got *.exe files, also *.ralf. I am using rtems4.10.
>> >> >> >> > I
>> >> >> >> > am
>> >> >> >> > using
>> >> >> >> > fedora-19.
>> >> >> >> > On Wed, Jan 22, 2014 at 11:12 PM, Gedare Bloom
>> >> >> >> > wrote:
>> >> >> >> >> I think you should also have gotten *.exe files for that
>> >> >> >> >> target?
>> >> >> >> >> What
>> >> >> >> >> version of RTEMS are you using?
>> >> >> >> >> The instructions at http://wiki.rtems.org/wiki/index.php/Qemu
>> >> >> >> >> describe
>> >> >> >> >> how to use Qemu with RTEMS especially on the i386. That is a
>> >> >> >> >> good
>> >> >> >> >> simulator to use and work with, as it also works for a lot of
>> >> >> >> >> other
>> >> >> >> >> RTEMS targets.
>> >> >> >> >> -G
>> >> >> >> >> On Wed, Jan 22, 2014 at 12:07 PM, Garvit Sharma
>> >> >> >> >> wrote:
>> >> >> >> >> > Hi, I have done with the following tasks :
>> >> >> >> >> > 1. Installed GNU cross-compilation tools for RTEMS on my
>> >> >> >> >> > host
>> >> >> >> >> > system.
>> >> >> >> >> > 2. Installed RTEMS OS for the target host.
>> >> >> >> >> > 3. I have chosen the target as i386 and BSP as i386/pc686.
>> >> >> >> >> > 4. I have build the examples and from that I got *.ralf
>> >> >> >> >> > files.
>> >> >> >> >> > I
>> >> >> >> >> > know
>> >> >> >> >> > these
>> >> >> >> >> > files are executables which are to be run on target machine.
>> >> >> >> >> > But
>> >> >> >> >> > how
>> >> >> >> >> > to
>> >> >> >> >> > do
>> >> >> >> >> > so ? Is not there any simulator for that ?
>> >> >> >> >> > Thanks,
>> >> >> >> >> > On Wed, Jan 22, 2014 at 9:00 PM, Gedare Bloom
>> >> >> >> >> > wrote:
>> >> >> >> >> >> Probably the easiest place to start is
>> >> >> >> >> >> http://www.rtems.org/wiki/index.php/GSoC_Getting_Started
>> >> >> >> >> >> You may like to build the tools using the RSB:
>> >> >> >> >> >> http://www.rtems.org/wiki/index.php/RSB
>> >> >> >> >> >> -Gedare
>> >> >> >> >> >> On Wed, Jan 22, 2014 at 6:16 AM, Garvit Sharma
>> >> >> >> >> >> wrote:
>> >> >> >> >> >> > Hi, I have installed cross-compiler toolsets and now it
>> >> >> >> >> >> > is
>> >> >> >> >> >> > the
>> >> >> >> >> >> > time
>> >> >> >> >> >> > to
>> >> >> >> >> >> > build
>> >> >> >> >> >> > rtems from the source. I want to know that for which
>> >> >> >> >> >> > target
>> >> >> >> >> >> > architecture
>> >> >> >> >> >> > should I build rtems.
>> >> >> >> >> >> > On Wed, Jan 22, 2014 at 11:50 AM, Nick Withers
>> >> >> >> >> >> > <nick.withers at anu.edu.au>
>> >> >> >> >> >> > wrote:
>> >> >> >> >> >> >> On Wed, 2014-01-22 at 11:41 +0530, Garvit Sharma wrote:
>> >> >> >> >> >> >> > Hello All,
>> >> >> >> >> >> >> > I am a newbie to the world of rtems and want to make
>> >> >> >> >> >> >> > contributions
>> >> >> >> >> >> >> > towards rtems. I have experience with
>> >> >> >> >> >> >> > C/SystemProgramming/DeviceDrivers and gnu tools like
>> >> >> >> >> >> >> > gdb,
>> >> >> >> >> >> >> > strace
>> >> >> >> >> >> >> > and
>> >> >> >> >> >> >> > Oprofile. Please show me the direction to start from.
>> >> >> >> >> >> >> Hi Garvit!
>> >> >> >> >> >> >> (Humble user here)
>> >> >> >> >> >> >> Glad to hear you want to contribute, that's awesome :-)
>> >> >> >> >> >> >> Perhaps have a look at
>> >> >> >> >> >> >> http://www.rtems.org/wiki/index.php/Contributing#How_can_I_help.3F ?
>> >> >> >> >> >> >> It's got both coding and non-coding suggestions that
>> >> >> >> >> >> >> might
>> >> >> >> >> >> >> help.
>> >> >> >> >> >> >> Looking forward to your contributions :-)
>> >> >> >> >> >> >> Nick Withers
>> >> >> >> >> >> >> Embedded Systems Programmer
>> >> >> >> >> >> >> Department of Nuclear Physics, Research School of
>> >> >> >> >> >> >> Physics
>> >> >> >> >> >> >> and
>> >> >> >> >> >> >> Engineering
>> >> >> >> >> >> >> The Australian National University (CRICOS: 00120C)
>> >> >> >> >> >> >> > Thanks,
>> >> >> >> >> >> >> > Garvit Sharma
>> >> >> >> >> >> >> > B.Tech | Computer Science and Engineering
>> >> >> >> >> >> >> > UG Final year
>> >> >> >> >> >> >> > LNM IIT, Jaipur
>> >> >> >> >> >> >> > No Body is a Scholar by birth, its only hard work and
>> >> >> >> >> >> >> > strong
>> >> >> >> >> >> >> > determination that makes him master.
>> >> >> >> >> >> >> > _______________________________________________
>> >> >> >> >> >> >> > rtems-users mailing list
>> >> >> >> >> >> >> > rtems-users at rtems.org
>> >> >> >> >> >> >> > http://www.rtems.org/mailman/listinfo/rtems-users
>> >> >> >> >> >> > Garvit Sharma
>> >> >> >> >> >> > UG Final year
>> >> >> >> >> >> > LNM IIT, Jaipur
>> >> >> >> >> >> > strong
>> >> >> >> >> >> > determination
>> >> >> >> >> > Garvit Sharma
>> >> >> >> >> > UG Final year
>> >> >> >> >> > LNM IIT, Jaipur
>> >> >> >> >> > No Body is a Scholar by birth, its only hard work and strong
>> >> >> >> >> > determination
>> >> >> >> > Garvit Sharma
>> >> >> >> > UG Final year
>> >> >> >> > LNM IIT, Jaipur
>> >> >> >> > determination
>> >> >> > Garvit Sharma
>> >> >> > UG Final year
>> >> >> > LNM IIT, Jaipur
>> >> >> > determination
>> >> > Garvit Sharma
>> >> > UG Final year
>> >> > LNM IIT, Jaipur
>> >> > determination
>> > Garvit Sharma
>> > UG Final year
>> > LNM IIT, Jaipur
>> > determination
> Garvit Sharma
> UG Final year
> LNM IIT, Jaipur
> No Body is a Scholar by birth, its only hard work and strong determination
