Interested in contribute to RTEMS
Garvit Sharma garvits45 at gmail.com
Fri Jan 24 19:50:45 UTC 2014
It worked using rtems-testing. What it is doing actually ??
On Fri, Jan 24, 2014 at 11:31 PM, Gedare Bloom <gedare at rtems.org> wrote:
> That looks about right, so I am not sure what is going wrong. I have
> not used Qemu with pc386 like this in a few years. You could try
> poking around in the GRUB shell, there are some basic commands
> available you can use to try to set the root and boot manually.
> Otherwise, I would suggest trying out the
> rtems-testing.git/sim-scripts/pc386 script just to get something that
> works and come back to debug later if needed.
> Gedare
> On Fri, Jan 24, 2014 at 12:46 PM, Garvit Sharma <garvits45 at gmail.com>
> wrote:
> > I have done the following things :
> >>> mke2fs hda.img
> >>> mkdir /mount/mount_point
> >>> mount -o loop hda.img /mount/mount_point
> >>> cp rtems-grub.cfg /mount/mount_point
> > Let me know whether or not I did correctly
> > On Fri, Jan 24, 2014 at 10:12 PM, Gedare Bloom <gedare at rtems.org> wrote:
> >> I prefer if you can keep your questions on the mailing list. You may
> >> get other answers there, and others may benefit from your questions.
> >> -Gedare
> >> On Fri, Jan 24, 2014 at 11:40 AM, Garvit Sharma <garvits45 at gmail.com>
> >> wrote:
> >> > I have placed the rtems-grub.cfg in the same folder but still it is
> >> > showing
> >> > me the grub shell
> >> > On Fri, Jan 24, 2014 at 8:45 PM, Gedare Bloom <gedare at rtems.org>
> wrote:
> >> >> If you are following the instructions on our wiki, then you need to
> >> >> have a rtems-grub.cfg located in your hda.img file. You might also
> >> >> like to try the instructions related to the "rtems-testing.git"
> >> >> module.
> >> >> -Gedare
> >> >> On Fri, Jan 24, 2014 at 10:05 AM, Garvit Sharma <garvits45 at gmail.com
> >> >> wrote:
> >> >> > Hi, I am executing the following command on my system
> >> >> >>> qemu-system-i386 -m 128 -boot a -fda rtems-boot.img -hda hda.img
> >> >> >>> -hdb
> >> >> >>> fat:. -serial stdio -no-reboot -s
> >> >> > after that gui of qemu appeared and it consists of grub shell. I am
> >> >> > not
> >> >> > getting what to do next.
> >> >> > On Wed, Jan 22, 2014 at 11:46 PM, Gedare Bloom <gedare at rtems.org>
> >> >> > wrote:
> >> >> >> You might like to consider going to the task list for Google
> Code-In
> >> >> >> [1] and filter for "RTEMS" as the Organization field and "open"
> for
> >> >> >> the Status field. These tasks are relatively easy to get started
> on
> >> >> >> so
> >> >> >> you can look for something that might interest you. There are some
> >> >> >> possible bug fixes and some test case refactoring tasks.
> >> >> >> [1] http://www.google-melange.com/gci/tasks/google/gci2013
> >> >> >> On Wed, Jan 22, 2014 at 1:03 PM, Garvit Sharma <
> >> >> >> wrote:
> >> >> >> > I am configuring qemu to see examples working, In the meanwhile
> >> >> >> > please
> >> >> >> > tell
> >> >> >> > me how should I make my first contribution to this organization.
> >> >> >> > Which
> >> >> >> > bug
> >> >> >> > should I start with ?
> >> >> >> > On Wed, Jan 22, 2014 at 11:21 PM, Gedare Bloom <
> >> >> >> > wrote:
> >> >> >> >> ok. for 4.10 i think it should "just work". For new
> development,
> >> >> >> >> we
> >> >> >> >> suggest using 4.11 (the current git master). We only accept bug
> >> >> >> >> fixes
> >> >> >> >> submitted to 4.10. Hopefully a 4.11 release will come soon!
> >> >> >> >> -Gedare
> >> >> >> >> On Wed, Jan 22, 2014 at 12:45 PM, Garvit Sharma
> >> >> >> >> wrote:
> >> >> >> >> > yes, I have got *.exe files, also *.ralf. I am using
> rtems4.10.
> >> >> >> >> > I
> >> >> >> >> > am
> >> >> >> >> > using
> >> >> >> >> > fedora-19.
> >> >> >> >> > On Wed, Jan 22, 2014 at 11:12 PM, Gedare Bloom
> >> >> >> >> > wrote:
> >> >> >> >> >> I think you should also have gotten *.exe files for that
> >> >> >> >> >> target?
> >> >> >> >> >> What
> >> >> >> >> >> version of RTEMS are you using?
> >> >> >> >> >> The instructions at
> http://wiki.rtems.org/wiki/index.php/Qemu
> >> >> >> >> >> describe
> >> >> >> >> >> how to use Qemu with RTEMS especially on the i386. That is a
> >> >> >> >> >> good
> >> >> >> >> >> simulator to use and work with, as it also works for a lot
> of
> >> >> >> >> >> other
> >> >> >> >> >> RTEMS targets.
> >> >> >> >> >> -G
> >> >> >> >> >> On Wed, Jan 22, 2014 at 12:07 PM, Garvit Sharma
> >> >> >> >> >> wrote:
> >> >> >> >> >> > Hi, I have done with the following tasks :
> >> >> >> >> >> > 1. Installed GNU cross-compilation tools for RTEMS on my
> >> >> >> >> >> > host
> >> >> >> >> >> > system.
> >> >> >> >> >> > 2. Installed RTEMS OS for the target host.
> >> >> >> >> >> > 3. I have chosen the target as i386 and BSP as i386/pc686.
> >> >> >> >> >> > 4. I have build the examples and from that I got *.ralf
> >> >> >> >> >> > files.
> >> >> >> >> >> > I
> >> >> >> >> >> > know
> >> >> >> >> >> > these
> >> >> >> >> >> > files are executables which are to be run on target
> machine.
> >> >> >> >> >> > But
> >> >> >> >> >> > how
> >> >> >> >> >> > to
> >> >> >> >> >> > do
> >> >> >> >> >> > so ? Is not there any simulator for that ?
> >> >> >> >> >> > Thanks,
> >> >> >> >> >> > On Wed, Jan 22, 2014 at 9:00 PM, Gedare Bloom
> >> >> >> >> >> > wrote:
> >> >> >> >> >> >> Probably the easiest place to start is
> >> >> >> >> >> >> http://www.rtems.org/wiki/index.php/GSoC_Getting_Started
> >> >> >> >> >> >> You may like to build the tools using the RSB:
> >> >> >> >> >> >> http://www.rtems.org/wiki/index.php/RSB
> >> >> >> >> >> >> -Gedare
> >> >> >> >> >> >> On Wed, Jan 22, 2014 at 6:16 AM, Garvit Sharma
> >> >> >> >> >> >> wrote:
> >> >> >> >> >> >> > Hi, I have installed cross-compiler toolsets and now it
> >> >> >> >> >> >> > is
> >> >> >> >> >> >> > the
> >> >> >> >> >> >> > time
> >> >> >> >> >> >> > to
> >> >> >> >> >> >> > build
> >> >> >> >> >> >> > rtems from the source. I want to know that for which
> >> >> >> >> >> >> > target
> >> >> >> >> >> >> > architecture
> >> >> >> >> >> >> > should I build rtems.
> >> >> >> >> >> >> > On Wed, Jan 22, 2014 at 11:50 AM, Nick Withers
> >> >> >> >> >> >> > <nick.withers at anu.edu.au>
> >> >> >> >> >> >> > wrote:
> >> >> >> >> >> >> >> On Wed, 2014-01-22 at 11:41 +0530, Garvit Sharma
> wrote:
> >> >> >> >> >> >> >> > Hello All,
> >> >> >> >> >> >> >> > I am a newbie to the world of rtems and want to make
> >> >> >> >> >> >> >> > contributions
> >> >> >> >> >> >> >> > towards rtems. I have experience with
> >> >> >> >> >> >> >> > C/SystemProgramming/DeviceDrivers and gnu tools like
> >> >> >> >> >> >> >> > gdb,
> >> >> >> >> >> >> >> > strace
> >> >> >> >> >> >> >> > and
> >> >> >> >> >> >> >> > Oprofile. Please show me the direction to start
> from.
> >> >> >> >> >> >> >> Hi Garvit!
> >> >> >> >> >> >> >> (Humble user here)
> >> >> >> >> >> >> >> Glad to hear you want to contribute, that's awesome
> >> >> >> >> >> >> >> Perhaps have a look at
> http://www.rtems.org/wiki/index.php/Contributing#How_can_I_help.3F ?
> >> >> >> >> >> >> >> It's got both coding and non-coding suggestions that
> >> >> >> >> >> >> >> might
> >> >> >> >> >> >> >> help.
> >> >> >> >> >> >> >> Looking forward to your contributions :-)
> >> >> >> >> >> >> >> Nick Withers
> >> >> >> >> >> >> >> Embedded Systems Programmer
> >> >> >> >> >> >> >> Department of Nuclear Physics, Research School of
> >> >> >> >> >> >> >> Physics
> >> >> >> >> >> >> >> and
> >> >> >> >> >> >> >> Engineering
> >> >> >> >> >> >> >> The Australian National University (CRICOS: 00120C)
> >> >> >> >> >> >> >> > Thanks,
> >> >> >> >> >> >> >> > Garvit Sharma
> >> >> >> >> >> >> >> > B.Tech | Computer Science and Engineering
> >> >> >> >> >> >> >> > UG Final year
> >> >> >> >> >> >> >> > LNM IIT, Jaipur
> >> >> >> >> >> >> >> > No Body is a Scholar by birth, its only hard work
> and
> >> >> >> >> >> >> >> > strong
> >> >> >> >> >> >> >> > determination that makes him master.
> >> >> >> >> >> >> >> > _______________________________________________
> >> >> >> >> >> >> >> > rtems-users mailing list
> >> >> >> >> >> >> >> > rtems-users at rtems.org
> >> >> >> >> >> >> >> > http://www.rtems.org/mailman/listinfo/rtems-users
> >> >> >> >> >> >> > Garvit Sharma
> >> >> >> >> >> >> > UG Final year
> >> >> >> >> >> >> > LNM IIT, Jaipur
> >> >> >> >> >> >> > No Body is a Scholar by birth, its only hard work and
> >> >> >> >> >> >> > strong
> >> >> >> >> >> >> > determination
> >> >> >> >> >> > Garvit Sharma
> >> >> >> >> >> > UG Final year
> >> >> >> >> >> > LNM IIT, Jaipur
> strong
> >> >> >> >> >> > determination
> >> >> >> >> > Garvit Sharma
> >> >> >> >> > UG Final year
> >> >> >> >> > LNM IIT, Jaipur
> >> >> >> >> > No Body is a Scholar by birth, its only hard work and strong
> >> >> >> >> > determination
> >> >> >> > Garvit Sharma
> >> >> >> > UG Final year
> >> >> >> > LNM IIT, Jaipur
> >> >> >> > determination
> >> >> > Garvit Sharma
> >> >> > UG Final year
> >> >> > LNM IIT, Jaipur
> >> >> > determination
> >> > Garvit Sharma
> >> > UG Final year
> >> > LNM IIT, Jaipur
> >> > determination
> > Garvit Sharma
> > UG Final year
> > LNM IIT, Jaipur
> determination
Garvit Sharma
UG Final year
LNM IIT, Jaipur
*No Body is a Scholar by birth, its only hard work and strong determination
that makes him master.*
URL: <http://lists.rtems.org/pipermail/users/attachments/20140125/eafc891d/attachment-0001.html>
