RTEMS available tasks
    Andre Marques
    andre.lousa.marques at gmail.com
    Mon Jan 27 12:30:19 UTC 2014
On 01/27/14 08:00, Sebastian Huber wrote:
> Hello Andre,
> On 2014-01-26 01:31, Andre Marques wrote:
>> Hello,
>> I'm a CS undergraduate student and i've decided to do something RTEMS
>> related
>> for my final project.
> this is nice.
>> I already have a RTEMS build (4.11) working on my Gentoo system and
>> played a
>> bit with the EDF and RM schedulers (just launching some tasks and
>> counting the
>> deadline misses).
> Which BSP do you use?  If you want to work with a simulator BSP, then
> you should have a look at the arm/realview_pbx_a9_qemu BSP since it
> offers a NULL pointer read and write protection.  Qemu is also a fast
> simulator which provides support for GDB watch points.  This is quite
> handy for development and test suite runs.
I'm using the pc386 BSP using Qemu with the pc386 script provided on
rtems_testing. Only today I tested GDB with Qemu, which I'm finding a
bit tricky with the pc386 script because as soon as the program finishes
It closes Qemu, so I can't connect to the gdb server. To solve that I
used the instructions on the Wiki about Qemu (which seems to be a little
outdated, so I needed to change some steps) and I can now load a program
and connect to the gdb server, but I don't have the symbol table for any
program. I can't recall enabling debugging during the rtems configure
stage, but will that generate symbol tables for every compiled program?
Can't I just generate a symbol table for a specific program?
>> As of right now i'm between semesters, and looking to fill this gap
>> with some
>> coding fun. In [1] there is a task for making the implementation of
>> rename()
>> POSIX conformant. If this task is still open I would like to start
>> working on it.
> Yes, this task is still open and it is a good start point.
> I would start with a new test in
> http://git.rtems.org/rtems/tree/testsuites/fstests/
> which covers the POSIX rename() specification
> http://pubs.opengroup.org/onlinepubs/9699919799/functions/rename.html
In that case that's where I'm going to start. Any questions that I might
have should I post them on the users list or somewhere else?
>> I also went through the Google Code-In open tasks and found this bug
>> [2][3],
> Fixing this bug is a very boring task.  You have to install also the
> tool chain for each RTEMS target and build all BSPs.
>> which I could also work on, but if there's anything more interesting
>> (possibly
>> some small task related with scheduling) please let me know.
>> [1] -
>> https://wiki.rtems.org/wiki/index.php/Open_Projects#API_Layers_.28POSIX.2C_Classic.2C_SAPI.29
>> [2] -
>> http://www.google-melange.com/gci/task/view/google/gci2013/5227914052239360
>> [3] - https://www.rtems.org/bugzilla/show_bug.cgi?id=1279
>> Thanks for your time,
>> Andre Marques.
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
