RTEMS available tasks
Mon Jan 27 12:56:56 UTC 2014
On 2014-01-27 13:30, Andre Marques wrote:
> On 01/27/14 08:00, Sebastian Huber wrote:
>> Hello Andre,
>> On 2014-01-26 01:31, Andre Marques wrote:
>>> Hello,
>>> I'm a CS undergraduate student and i've decided to do something RTEMS related
>>> for my final project.
>> this is nice.
>>> I already have a RTEMS build (4.11) working on my Gentoo system and played a
>>> bit with the EDF and RM schedulers (just launching some tasks and counting the
>>> deadline misses).
>> Which BSP do you use?  If you want to work with a simulator BSP, then you
>> should have a look at the arm/realview_pbx_a9_qemu BSP since it offers a NULL
>> pointer read and write protection.  Qemu is also a fast simulator which
>> provides support for GDB watch points.  This is quite handy for development
>> and test suite runs.
> I'm using the pc386 BSP using Qemu with the pc386 script provided on
> rtems_testing. Only today I tested GDB with Qemu, which I'm finding a bit
> tricky with the pc386 script because as soon as the program finishes It closes
> Qemu, so I can't connect to the gdb server. To solve that I used the
> instructions on the Wiki about Qemu (which seems to be a little outdated, so I
> needed to change some steps) and I can now load a program and connect to the
> gdb server, but I don't have the symbol table for any program. I can't recall
> enabling debugging during the rtems configure stage, but will that generate
> symbol tables for every compiled program? Can't I just generate a symbol table
> for a specific program?
With the arm/realview_pbx_a9_qemu BSP I use this.
1. Start Qemu in one window:
qemu-system-arm -nographic -M realview-pbx-a9 -m 256M -kernel app.exe -s -S
2. Connect with GDB:
arm-rtems4.11-gdb app.exe
tar remote :1234
load
continue
You don't have to restart Qemu to load a new program, e.g. you can use the
following GDB function:
def new
make
monitor system_reset
load
continue
end
>>> As of right now i'm between semesters, and looking to fill this gap with some
>>> coding fun. In [1] there is a task for making the implementation of rename()
>>> POSIX conformant. If this task is still open I would like to start working
>>> on it.
>> Yes, this task is still open and it is a good start point.
>> I would start with a new test in
>> http://git.rtems.org/rtems/tree/testsuites/fstests/
>> which covers the POSIX rename() specification
>> http://pubs.opengroup.org/onlinepubs/9699919799/functions/rename.html
> In that case that's where I'm going to start. Any questions that I might have
> should I post them on the users list or somewhere else?
That list or to the rtems-devel list.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
