RTEMS available tasks
Garvit Sharma garvits45 at gmail.com
Wed Jan 29 07:10:59 UTC 2014
I was also facing the same problem with i386 qemu. But now I am using
rtems-testing to see the output, its working fine!!.
On Tue, Jan 28, 2014 at 11:03 PM, Sebastian Huber <
> On 2014-01-28 19:46, Andre Marques wrote:
>> On 01/28/14 14:34, Sebastian Huber wrote:
>>> On 2014-01-28 15:30, Andre Marques wrote:
>>>> Well, for me Qemu seems to be having some problems with the output,
>>>> because I
>>>> can set breakpoints, and run the code on the remote target, but Qemu
>>>> doesn't
>>>> show any output (with -nographic, and different consoles), or shows the
>>>> output
>>>> for the program passed with the -kernel parameter, regardless of what
>>>> gdb says
>>>> that is printing.
>>>> For now I guess I'm leaving this as it is, as I've tried for several
>>>> hours
>>>> already to make the output work.
>>>> On pc386 the -S option leads to a fatal error, because when loading the
>>>> program
>>>> it seems to load it on the Bios memory space. If I dont use that option
>>>> all
>>>> seems to work. As for arm, I could't get any output.
>>> Which Qemu version do you use?  I normally use the latest Git version.
>>> If you omit the -nographic option, then you need "-serial stdio".
>>> The output appears on the terminal running Qemu (not the GDB terminal).
>>>  I'm using Qemu 1.5.3 from the Gentoo repositories.  It runs the program
>> (passed
>> with -kernel), then stays with "Any key to reboot...". Meanwhile I can
>> connect
>> to Qemu with gdb, load some other program and then Qemu shows nothing,
>> just
>> waits again.
>> I'm using:
>> qemu-system-i386 -m 256M -kernel hello.exe -s -serial stdio
> I doubt this will work on i386 Qemu.  Here you need a boot loader, e.g.
> GRUB. That is one of reasons I don't use the i386 Qemu.  I would use the
> arm/realview_pbx_a9_qemu BSP with the latest Git version of Qemu.
> rtems-users mailing list
> rtems-users at rtems.org
Garvit Sharma
B.Tech | Computer Science and Engineering
UG Final year
LNM IIT, Jaipur
*No Body is a Scholar by birth, its only hard work and strong determination
that makes him master.*
URL: <http://lists.rtems.org/pipermail/users/attachments/20140128/051476d5/attachment-0001.html>
