RTEMS available tasks
Wed Jan 29 13:38:26 UTC 2014
On 2014-01-29 14:29, Andre Marques wrote:
> About debugging I hadn't much luck with pc386, so I followed your suggestion
> and installed Qemu from the latest Git and tested it with arm/realview-pbx-a9 BSP.
> Two issues there:
> - The loaded program never stops running;
> - I can't load another program on the same Qemu run with GDB, It always runs
> the program loaded initially (this also happened on pc386, so it must be
> something on GDB).
> I'm running GDB like this:
> tar remote :1234
> load
> continue (have to do Ctrl-c, because it doesn't stop running after this)
Yes, the program runs now.
> To load another program:
> monitor system_reset
> load
> continue (just resumes the initially loaded program instead)
If you want to change the ELF file, then use the "file" GDB command.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
