Including 3rd party library headers?
Nick Withers nick.withers at anu.edu.au
Wed Jan 29 22:15:21 UTC 2014
On Wed, 2014-01-29 at 22:29 +1300, James Fitzsimons wrote:
> Thanks Andrei,
> I'm using a very plain vanilla environment at the moment. Ubuntu 13.10
> with tool chain built using rtems source builder.
> I'm using the template makefile for my test application, and am just
> running make directly from bash.
> No IDE or fancy build environment yet!
I'd've said the RTEMS'provided Makefiles (there are a number of them,
chained together) are pretty fancy... But then, I have trouble with just
one Makefile :-P
Anyway, try:
	CFLAGS+=-I/bam/headers
> Cheers,
> James
> On 29 January 2014 17:01, Andrei Chichak <groups at chichak.ca> wrote:
>         I believe what Sebastian is referring to is the environment
>         that you are using for your compiles. In my case, I am using a
>         Mac and Eclipse, I set <C/C++ Build><Settings><Tool
>         Settings><RTEMS C Compiler><Preprocessor><Include Paths (-I)>.
>         Your milage will vary, but if you tell us what you are
>         driving, there may be someone here that can help.
>         Andrei
>         On 2014-January-28, at 2:11 PM, James Fitzsimons
>         <james.fitzsimons at gmail.com> wrote:
>         > Hi Sebastian,
>         > Thanks for your reply.
>         > Ideally I was hoping to us the -I option to specify the
>         header file location, I just can't quite figure out where to
>         add that into the RTEMS makefile structure. Looking at the
>         make/README I can see a good example of how to link in other
>         libraries using LD_LIBS, but there's nothing about including
>         other header files.
>         > Apologies if I am missing something obvious!
>         _______________________________________________
>         rtems-users mailing list
>         rtems-users at rtems.org
>         http://www.rtems.org/mailman/listinfo/rtems-users
Nick Withers
Embedded Systems Programmer
Department of Nuclear Physics, Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
