Including 3rd party library headers?
Simon Williams
williamssimonp at gmail.com
Wed Jan 29 23:31:19 UTC 2014
Wouldn't thst be -L for the lbrary path? The -l option is usef to specify a
library.
Also, linker flags are usually in LDFLAGS, CFLAGS is for compiler flags. It
does of course depend on your Makefile.
I would recommend Eclipse. It won't do everything for you, but it can help
by pointing the way!
Regards
Simon
On 29 Jan 2014 22:18, "Nick Withers" <nick.withers at anu.edu.au> wrote:
> On Wed, 2014-01-29 at 22:29 +1300, James Fitzsimons wrote:
> > Thanks Andrei,
> > I'm using a very plain vanilla environment at the moment. Ubuntu 13.10
> > with tool chain built using rtems source builder.
> > I'm using the template makefile for my test application, and am just
> > running make directly from bash.
> > No IDE or fancy build environment yet!
> I'd've said the RTEMS'provided Makefiles (there are a number of them,
> chained together) are pretty fancy... But then, I have trouble with just
> one Makefile :-P
> Anyway, try:
> CFLAGS+=-I/bam/headers
> > Cheers,
> > James
> > On 29 January 2014 17:01, Andrei Chichak <groups at chichak.ca> wrote:
> > I believe what Sebastian is referring to is the environment
> > that you are using for your compiles. In my case, I am using a
> > Mac and Eclipse, I set <C/C++ Build><Settings><Tool
> > Settings><RTEMS C Compiler><Preprocessor><Include Paths (-I)>.
> > Your milage will vary, but if you tell us what you are
> > driving, there may be someone here that can help.
> > Andrei
> > On 2014-January-28, at 2:11 PM, James Fitzsimons
> > <james.fitzsimons at gmail.com> wrote:
> > > Hi Sebastian,
> > > Thanks for your reply.
> > > Ideally I was hoping to us the -I option to specify the
> > header file location, I just can't quite figure out where to
> > add that into the RTEMS makefile structure. Looking at the
> > make/README I can see a good example of how to link in other
> > libraries using LD_LIBS, but there's nothing about including
> > other header files.
> > > Apologies if I am missing something obvious!
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
> Nick Withers
> Embedded Systems Programmer
> Department of Nuclear Physics, Research School of Physics and Engineering
> The Australian National University (CRICOS: 00120C)
URL: <http://lists.rtems.org/pipermail/users/attachments/20140129/b2a730f9/attachment-0001.html>
