[HansHuang]Which is Nano-X version as scr_mx1sl.c?
Pavel Pisa
ppisa4lists at pikron.com
Tue Jul 22 12:41:32 UTC 2014
Hello Hans,
the MicroWindows/Nano-X structures little differs between
versions. It is some time I have pointed you to examples
so I do not exactly remember which version of our code
I have pointed to. We use older MW version in sysless
project because that version allows simpler adaptation
for indirect framebuffer updates and 16 bit word based
bitmaps/fonts acceleration for sub 8 BPP framebuffer
formats.
We use newer versions with RTEMS which has better
common bit-blit optimization for standard formats.
But example should be straightforward.
Sysless includes all required MW/NX source files directly.
As for RTEMS graphic toolkit, it is based on actual sources.
I am attaching patches for our HW which should apply to actual
MW/NX GIT. But they are mainly meant as examples for you.
I can prepare tarball of more MW versions which we use there
but I do not expect that it has so big value. They are GIT
or CVS snapshosts.
Best wishes,
Pavel
On Thursday 17 of July 2014 09:42:04 黄喜 wrote:
> Dear Pavel :
> Nice to send mail to you again.
> I browse the Microwindows code and found the order of member variables in
> scrdev structure of scr_rtems.c is different from scr_mx1sl.c file. I
> download the latest Microwindows code, May be your Microwindows code is
> another old one.Right?
> Thanks!
Type: text/x-diff
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20140722/bc982266/attachment-0004.bin>
Type: text/x-diff
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20140722/bc982266/attachment-0005.bin>
