RTEMS shell and telnetd
Sebastian Huber
Mon Jun 2 07:13:34 UTC 2014
On 2014-05-29 01:32, Chris Johns wrote:
> On 29/05/2014 1:13 am, Sebastian Huber wrote:
>> Hello Peter,
>> On 2014-05-28 17:04, Peter Dufault wrote:
>>> I'm figuring out how we're supposed to hook telnetd and RTEMS shell
>>> together in the git head and I don't understand the intent. I used to
>>> do it like this:
>>> static void sh_wrap(char *unused_dev, void *arg)
>>> rtems_shell_env_t my_env = rtems_global_shell_env;
>>> my_env.forever = false;
>>> (void)rtems_shell_main_loop( &my_env );
>>> rtems_telnetd_config_table rtems_telnetd_config = {
>>> sh_wrap, /* Command */
>>> NULL, /* Argument */
>>> 0, /* Priority */
>>> 20 * RTEMS_MINIMUM_STACK_SIZE, /* task stack size */
>>> 0, /* Login check */
>>> 0 /* Keep stdio of the caller */
>>> and later call:
>>> rtems_telnetd_initialize();
>>> "rtems_global_shell_env" is no longer global.
>>> "rtems_shell_init_env()" which would initialize a rtems_shell_env_t is
>>> not global. "rtems_shell_get_current_env()" won't work outside of a
>>> shell context. Passing 0 to rtems_shell_main_loop(0) will get the
>>> default settings for the shell env, so forever will be set true and I
>>> won't be able to exit the session.
>>> Am I missing something or is the intention I set up a "my_env"
>>> myself? rtems_shell_env_t is still global.
>> since so many user stumble over this problem I think we should bring
>> this global rtems_global_shell_env back as a read-only variable simply
>> to initialize rtems_shell_env_t variables.
> What is wrong with:
> rtems_shell_env_t shell_env = *rtems_shell_get_current_env();
I don't like this global, but it turned that this missing
rtems_global_shell_env is currently the number one support question of users
updating to the latest RTEMS version. At least now it is const.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
