RTEMS shell and telnetd
Chris Johns
chrisj at rtems.org
Wed Jun 4 01:14:04 UTC 2014
On 2/06/2014 5:13 pm, Sebastian Huber wrote:
> On 2014-05-29 01:32, Chris Johns wrote:
>> On 29/05/2014 1:13 am, Sebastian Huber wrote:
>>> Hello Peter,
>>> On 2014-05-28 17:04, Peter Dufault wrote:
>>>> I'm figuring out how we're supposed to hook telnetd and RTEMS shell
>>>> together in the git head and I don't understand the intent. I used to
>>>> do it like this:
>>>> static void sh_wrap(char *unused_dev, void *arg)
>>>> rtems_shell_env_t my_env = rtems_global_shell_env;
>>>> my_env.forever = false;
>>>> (void)rtems_shell_main_loop( &my_env );
>>>> rtems_telnetd_config_table rtems_telnetd_config = {
>>>> sh_wrap, /* Command */
>>>> NULL, /* Argument */
>>>> 0, /* Priority */
>>>> 20 * RTEMS_MINIMUM_STACK_SIZE, /* task stack size */
>>>> 0, /* Login check */
>>>> 0 /* Keep stdio of the caller */
>>>> and later call:
>>>> rtems_telnetd_initialize();
>>>> "rtems_global_shell_env" is no longer global.
>>>> "rtems_shell_init_env()" which would initialize a rtems_shell_env_t is
>>>> not global. "rtems_shell_get_current_env()" won't work outside of a
>>>> shell context. Passing 0 to rtems_shell_main_loop(0) will get the
>>>> default settings for the shell env, so forever will be set true and I
>>>> won't be able to exit the session.
>>>> Am I missing something or is the intention I set up a "my_env"
>>>> myself? rtems_shell_env_t is still global.
>>> since so many user stumble over this problem I think we should bring
>>> this global rtems_global_shell_env back as a read-only variable simply
>>> to initialize rtems_shell_env_t variables.
>> What is wrong with:
>> rtems_shell_env_t shell_env = *rtems_shell_get_current_env();
> I don't like this global, but it turned that this missing
> rtems_global_shell_env is currently the number one support question of
> users updating to the latest RTEMS version. At least now it is const.
That maybe the case but I do not see this as a reason to keep a poor
interface any longer than we need. I suggest we strengthen the API and
remove this variable and get things cleaned up.
I posted a patch on the devel list and no one has comments so can I
assume it is ok to push ?
