STM32F4Discovery
Christian Mauderer list+rtems at c-mauderer.de
Thu Jun 19 06:49:58 UTC 2014
Am 18.06.2014 20:16, schrieb Steven Grunza:
> {After a minute or so I hit ctrl-c}
> Program received signal SIGINT, Interrupt.
> 0x000050a2 in _Internal_error_Occurred
> (the_source=the_source at entry=RTEMS_FATAL_SOURCE_EXIT,
> is_internal=is_internal at entry=0x0,
>     the_error=0x0) at
> ../../../../../../rtems.svn/c/src/../../cpukit/score/src/interr.c:43
> (gdb)
Hello,
It seems that you got a fatal error. It would be useful to do a
backtrace ("bt" or "info stack") to see where you came from.
Further: Which version of rtems do you use? A stable release or a
current development version? You have a "rtems.svn" in your path. The
current development of rtems uses git. I'm not even sure where whether
the svn repository still exists or not.
Kind regards,
Christian Mauderer
