problem starting a rtems task
Martínez, Pablo
pabloa.mar at gmail.com
Wed Jun 25 14:56:52 UTC 2014
Hi,
Im having troubles trying to use the class rtemsTask from the the
librtems++.
https://github.com/atgreen/RTEMS/blob/master/c/src/librtems%2B%2B/include/rtems%2B%2B/rtemsTask.h
This class is basically a wrapper for the rtems task api.
I can create the task successfully (its returns 0), but when I call start()
the entry point origin doesnt start despite returning 0 (this method just
write a memory position to check if the task is working).
const rtems_status_code rtemsTask::start(const rtems_task_argument arg)
if (owner)
argument = arg;
// pass the this pointer as the argument
set_status_code(rtems_task_start(id,
origin,
(rtems_task_argument) this));
else
set_status_code(RTEMS_NOT_OWNER_OF_RESOURCE);
return last_status_code();
Any help?
best regards,
Martínez, Pablo Agustín
URL: <http://lists.rtems.org/pipermail/users/attachments/20140625/69faec97/attachment-0001.html>
