RTEMS on Beaglebone Black
Ben Gras beng at shrike-systems.com
Tue Jun 24 20:09:26 UTC 2014
All,
My BSP doesn't support it, but there is support in Minix for that hardware
which I intend to port given suitable circumstances (current BSP merged,
free time, practical in terms of sufficiently similar interfaces, ..).
On Tue, Jun 24, 2014 at 8:32 PM, Oyake, Amalaye (398K) <
amalaye.oyake at jpl.nasa.gov> wrote:
>   Hello Matthew,
>  How is networking on the BeagleBone with RTEMS?
>  Regards,
> * Amalaye Oyake                                       *
> * Instrument Product Software Development Group  */\  *
> * Jet Propulsion Laboratory, Pasadena            *||  *
> * CA 91109 818.393.7168 work   626.399.1707 cell /||\ *
>   From: Mathew Benson <mathew.benson at gmail.com>
> Date: Tuesday, June 24, 2014 6:57 AM
> To: Ben Gras <beng at shrike-systems.com>
> Cc: RTEMS <rtems-users at rtems.org>, Ben Gras <beng at few.vu.nl>
> Subject: Re: RTEMS on Beaglebone Black
>   You rock.  Thanks.
> Sent from my iPhone
> On Jun 24, 2014, at 8:53 AM, Ben Gras <beng at shrike-systems.com> wrote:
>   All,
>  Yes, I'm subscribed.
> Yes, I have a RTEMS BSP of the 4 beagle targets in progress - the
> beaglebaord, beagleboard xm, beaglebone white, and beaglebone black.
>  Code is at:
> https://github.com/bengras/rtems/tree/beaglebone-wip
>  Wiki page is at:
> http://wiki.rtems.org/wiki/index.php/Beagleboard
> The status is that the basics work but I want to get all (insofar as
> reasonable) tests passing on the bbxm and beaglebone. Also I'm working on a
> regression test setup using RTEMS tester. For which I'm using the RTEMS
> source builder so qemu-linaro is built. This way the bbxm regression test
> can be run without having the hardware.
>  The current code runs on the bbxm but I've had a failure-report on the
> beaglebones (earlier commits did work on the beaglebones) so I may have
> broken that, I haven't checked recently.
>  My roadmap is:
>    - run bbxm tests running using qemu-linaro
>    - debug bbxm tests in qemu-linaro
>    - debug bbxm tests on hardware
>    - debug beaglebone tests on hardware
> On Tue, Jun 24, 2014 at 3:27 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
> wrote:
>> Ben.. this is yours to answer. :)
>> I didn't know if you were subscribed.
>>  On 6/24/2014 8:14 AM, Mathew Benson wrote:
>> > Has anybody ported RTEMS to the Beaglebone Black?
>> > _______________________________________________
>> > users mailing list
>> > users at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/users
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20140624/4b2fb6b6/attachment-0002.html>
