problem starting a rtems task
Thu Jun 26 11:37:34 UTC 2014
On 26/06/2014 12:56 am, Martínez, Pablo wrote:
> Hi,
> Im having troubles trying to use the class rtemsTask from the the
> librtems++.
> https://github.com/atgreen/RTEMS/blob/master/c/src/librtems%2B%2B/include/rtems%2B%2B/rtemsTask.h
> This class is basically a wrapper for the rtems task api.
> I can create the task successfully (its returns 0), but when I call
> start() the entry point origin doesnt start despite returning 0 (this
> method just write a memory position to check if the task is working).
> const rtems_status_code rtemsTask::start(const rtems_task_argument arg)
> if (owner)
> argument = arg;
> // pass the this pointer as the argument
> set_status_code(rtems_task_start(id,
> origin,
> (rtems_task_argument) this));
> else
> set_status_code(RTEMS_NOT_OWNER_OF_RESOURCE);
> return last_status_code();
> Any help?
Are the priorities ok ? If not it might not be able to run.
> best regards,
> Martínez, Pablo Agustín
> users mailing list
> users at rtems.org
