rtems dynamic library loading
Mihaela Panescu
mihaela.panescu at gmail.com
Mon Jun 30 12:15:06 UTC 2014
Hi,
I have a problem load a dynamic library using rtems and rtl.
I have a basic dynamic library which should print "hello" using printf, but
when the library is loaded with dlopen(), the "global symbol nout found:
puts" message is returned.
I compile the library in a similar way as rtld test:
arm-rtems4.11-ar -rcs libbasic_math.a basic_math.o
rtems-ra --lib basic_math --output-path ./ --no-stdlibs --cc
arm-rtems4.11-gcc -Wl,-static -L$(RTEMS_TOOLCHAIN)/arm-rtems4.11/lib -l c
arm-rtems4.11-ar x libbasic_math.ra
I also tried to compile it with:
rtems-ld -o basic_math.elf -O a -n -b dll.exe -e Init --cc
arm-rtems4.11-gcc basic_math.o -L$(RTEMS_TOOLCHAIN)/arm-rtems4.11/lib -l c
, but no luck:
Thank you,
Mihaela
URL: <http://lists.rtems.org/pipermail/users/attachments/20140630/a974de43/attachment.html>
