POSIX semaphores across ISR/non-ISR contexts
Sebastian Huber
Mon Jun 30 12:55:27 UTC 2014
On 2014-06-30 14:46, Ingolf Steinbach wrote:
> 2014-06-27 8:46 GMT+02:00 Sebastian Huber<sebastian.huber at embedded-brains.de>:
>> >In case this is used for debugging only, then I would disable interrupts
>> >instead of using a semaphore.
> Is replacing the semaphore-based method by disabling interrupts safe
> in the presence of SMP (the GR712RC has two cores)?
No, in this case use interrupt locks:
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__ClassicINTRLocks.html
On SMP configurations the usage of the ISR nest level is questionable.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
