RTEMS on Beaglebone Black
Oyake, Amalaye (398K)
amalaye.oyake at jpl.nasa.gov
Tue Jun 24 18:32:27 UTC 2014
Hello Matthew,
How is networking on the BeagleBone with RTEMS?
Regards,
* Amalaye Oyake *
* Instrument Product Software Development Group */\ *
* Jet Propulsion Laboratory, Pasadena *|| *
* CA 91109 818.393.7168 work 626.399.1707 cell /||\ *
From: Mathew Benson <mathew.benson at gmail.com<mailto:mathew.benson at gmail.com>>
Date: Tuesday, June 24, 2014 6:57 AM
To: Ben Gras <beng at shrike-systems.com<mailto:beng at shrike-systems.com>>
Cc: RTEMS <rtems-users at rtems.org<mailto:rtems-users at rtems.org>>, Ben Gras <beng at few.vu.nl<mailto:beng at few.vu.nl>>
Subject: Re: RTEMS on Beaglebone Black
You rock. Thanks.
Sent from my iPhone
On Jun 24, 2014, at 8:53 AM, Ben Gras <beng at shrike-systems.com<mailto:beng at shrike-systems.com>> wrote:
All,
Yes, I'm subscribed.
Yes, I have a RTEMS BSP of the 4 beagle targets in progress - the beaglebaord, beagleboard xm, beaglebone white, and beaglebone black.
Code is at:
https://github.com/bengras/rtems/tree/beaglebone-wip
Wiki page is at:
http://wiki.rtems.org/wiki/index.php/Beagleboard
The status is that the basics work but I want to get all (insofar as reasonable) tests passing on the bbxm and beaglebone. Also I'm working on a regression test setup using RTEMS tester. For which I'm using the RTEMS source builder so qemu-linaro is built. This way the bbxm regression test can be run without having the hardware.
The current code runs on the bbxm but I've had a failure-report on the beaglebones (earlier commits did work on the beaglebones) so I may have broken that, I haven't checked recently.
My roadmap is:
- run bbxm tests running using qemu-linaro
- debug bbxm tests in qemu-linaro
- debug bbxm tests on hardware
- debug beaglebone tests on hardware
On Tue, Jun 24, 2014 at 3:27 PM, Joel Sherrill <joel.sherrill at oarcorp.com<mailto:joel.sherrill at oarcorp.com>> wrote:
Ben.. this is yours to answer. :)
I didn't know if you were subscribed.
On 6/24/2014 8:14 AM, Mathew Benson wrote:
> Has anybody ported RTEMS to the Beaglebone Black?
> users mailing list
> users at rtems.org<mailto:users at rtems.org>
joel.sherrill at OARcorp.com<mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
Support Available (256) 722-9985<tel:%28256%29%20722-9985>
users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20140624/29622b99/attachment-0002.html>
