2014-06-27 8:46 GMT+02:00 Sebastian Huber <sebastian.huber at embedded-brains.de>: > In case this is used for debugging only, then I would disable interrupts > instead of using a semaphore. Is replacing the semaphore-based method by disabling interrupts safe in the presence of SMP (the GR712RC has two cores)? Ingolf
