Creating a new BSP
Steven Grunza
steven.grunza at gmail.com
Mon Jun 30 20:24:47 UTC 2014
That was the problem. I didn't change
c/src/lib/libbsp/arm/m4robot/make/custom/stm32f4.cfg to m4robot.cfg
Thanks.
On Mon, Jun 30, 2014 at 3:28 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>
wrote:
> Did you rename the make/custom file to match your BSP name?
> On Jun 30, 2014 2:20 PM, Steven Grunza <steven.grunza at gmail.com> wrote:
> Can I create a new BSP by copying a very similar BSP (such as stm32f4)
> and then adding the new directory to the acinclude.m4 file
> in c/src/lib/libbsp/arm, then running bootstrap from the top level
> directory?
> As far as I can remember this is the procedure I used to create a BSP
> for the STM32F3Discovery board; however, now that I need to use a
> STM32F4Discovery (with really different pinouts than the current BSP) I'm
> having trouble getting the system to configure. My configure output ends
> with ...
> checking whether gmake sets $(MAKE)... yes
> checking whether gmake supports nested variables... yes
> checking whether to enable maintainer-specific portions of Makefiles... yes
> checking that generated files are newer than configure... done
> configure: creating ./config.status
> config.status: creating Makefile
> My STM32F3Discovery configuration output ends with ...
> target architecture: arm.
> available BSPs: stm32f3.
> 'gmake all' will build the following BSPs: stm32f3.
> other BSPs can be built with 'gmake RTEMS_BSP="bsp1 bsp2 ..."'
> My best guess is that I've forgotten to update a file but I haven't been
> able to figure out which file. Any suggestions would be appreciated.
> My development system is Fedora 20, I'm using recent "arm-rtems4.11-xxx"
> tools from yum and my source code is from GIT HEAD (albeit a while ago).
> My configuration commands are:
> ../rtems/configure --prefix=/home/rtems/rtems-411 --target=arm-rtems4.11
> --enable-posix --enable-networking --enable-cxx --enable-maintainer-mode
> --enable-rtemsbsp="stm32f3"
> --enable-rtemsbsp="m4robot"
> Steven G.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140630/6e42946e/attachment-0002.html>
