Creating a new BSP
Joel Sherrill Joel.Sherrill at OARcorp.com
Mon Jun 30 19:28:25 UTC 2014
Did you rename the make/custom file to match your BSP name?
On Jun 30, 2014 2:20 PM, Steven Grunza <steven.grunza at gmail.com> wrote:
Can I create a new BSP by copying a very similar BSP (such as stm32f4) and then adding the new directory to the acinclude.m4 file in c/src/lib/libbsp/arm, then running bootstrap from the top level directory?
As far as I can remember this is the procedure I used to create a BSP for the STM32F3Discovery board; however, now that I need to use a STM32F4Discovery (with really different pinouts than the current BSP) I'm having trouble getting the system to configure.  My configure output ends with ...
checking whether gmake sets $(MAKE)... yes
checking whether gmake supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
My STM32F3Discovery configuration output ends with ...
target architecture: arm.
available BSPs: stm32f3.
'gmake all' will build the following BSPs: stm32f3.
other BSPs can be built with 'gmake RTEMS_BSP="bsp1 bsp2 ..."'
My best guess is that I've forgotten to update a file but I haven't been able to figure out which file.  Any suggestions would be appreciated.
My development system is Fedora 20, I'm using recent "arm-rtems4.11-xxx" tools from yum and my source code is from GIT HEAD (albeit a while ago).
My configuration commands are:
../rtems/configure --prefix=/home/rtems/rtems-411 --target=arm-rtems4.11 --enable-posix --enable-networking --enable-cxx --enable-maintainer-mode --enable-rtemsbsp="stm32f3"
../rtems/configure --prefix=/home/rtems/rtems-411 --target=arm-rtems4.11 --enable-posix --enable-networking --enable-cxx --enable-maintainer-mode --enable-rtemsbsp="m4robot"
Steven G.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140630/6efbca6b/attachment-0002.html>
