SPARC Floating Point Context
Sebastian Huber
Wed Mar 5 14:26:25 UTC 2014
Hello,
I just noticed that the SPARC floating point unit (FPU) support is a bit odd:
1. the context switch saves and restores all 32 floating point registers (%f0
up to %f31) and the FSR
http://git.rtems.org/rtems/tree/cpukit/score/cpu/sparc/rtems/score/cpu.h#n551
2. the interrupt entry/exit doesn't save/restore the floating point registers.
Since we use the System V ABI, this makes no sense. Here all floating point
registers are volatile.
The SPARC V8 trap entry sequence doesn't disable the FPU via the PSR_EF bit.
So it seems that interrupt handler using the FPU can destroy the FPU context of
the interrupted thread?
For a System V ABI conforming implementation it should be:
1. the interrupt entry/exit must save/restore the floating point registers
to/from the stack of the interrupted thread
2. nothing more
What was the reason for the existing implementation?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
