source builder issue (unstable: expat-2.1.0-1 missing)
Karel Gardas karel.gardas at centrum.cz
Mon Mar 17 07:25:37 UTC 2014
Yes, like you I've been also able to build non-"unstable" tools for both
sparc and sparc64. The only reason why I attempted to build unstable
stuff is that both sis and qemu/leon3 have not worked for me. In case of
sis, it looks like a combination of user error where I assumed that simple:
sparc-rtems4.11-sis
./sparc-rtems4.11/c/sis/testsuites/samples/hello/hello.exe
go
should run, but instead of it I just get:
sis> go
resuming at 0x02000000
IU in error mode (257)
         4  02000000  00000000  Address 0x0000000002000000 is out of bounds.
Now, I know that I need to load the file like:
sis> load ./sparc-rtems4.11/c/sis/testsuites/samples/hello/hello.exe
sis> go
*** HELLO WORLD TEST ***
Hello World
*** END OF HELLO WORLD TEST ***
    128835  02001f38  91d02000  Address 0x0000000002001f38 is out of bounds.
but still this (for novice misleading) error message at the end remains.
With Qemu/Leon3 the story is probably a little bit different, I've seen
on the mailing list some messages about a topic and although using qemu
2.0.0rc0 it may be the case that not all Sebastian's patches are in in
order to have vanilla Leon3 BSP running...
Thanks!
Karel
On 03/17/14 12:19 AM, Gedare Bloom wrote:
> Do the non-"unstable" tools work for you? I don't know what the
> unstable signifies. I use Centos 6.5 and just built my tools
> (4.11/rtems-sparc and 4.11/rtems-sparc64) last week successfully.
> -Gedare
> On Sun, Mar 16, 2014 at 1:11 PM, Karel Gardas<karel.gardas at centrum.cz>  wrote:
>> Hello,
>> while trying source builder on CentOS 6.x on AMD64 machine I've hit
>> following issue:
>> ../source-builder/sb-set-builder --log=sparc.log
>> --prefix=/home/karel/sfw/rtems-sparc-head unstable/4.11/rtems-sparc.bset
>> RTEMS Source Builder - Set Builder, v0.2.0
>> Build Set: unstable/4.11/rtems-sparc.bset
>> error: unstable/4.11/rtems-sparc.bset:17: cannot find file: expat-2.1.0-1
>> Build FAILED
>> this is using today's source buidler head attempting to build RTEMS
>> unstable/4.11 tools.
>> Is there anything I may done in order to fix that?
>> Thanks!
>> Karel
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
