source builder issue (unstable: expat-2.1.0-1 missing)
Mon Mar 17 15:12:40 UTC 2014
On 3/17/2014 2:25 AM, Karel Gardas wrote:
> Yes, like you I've been also able to build non-"unstable" tools for both
> sparc and sparc64. The only reason why I attempted to build unstable
> stuff is that both sis and qemu/leon3 have not worked for me. In case of
> sis, it looks like a combination of user error where I assumed that simple:
> sparc-rtems4.11-sis
> ./sparc-rtems4.11/c/sis/testsuites/samples/hello/hello.exe
> go
> should run, but instead of it I just get:
> sis> go
> resuming at 0x02000000
> IU in error mode (257)
>          4  02000000  00000000  Address 0x0000000002000000 is out of bounds.
> Now, I know that I need to load the file like:
> sis> load ./sparc-rtems4.11/c/sis/testsuites/samples/hello/hello.exe
> sis> go
rtems-testing/sim-scripts hides the variances in a lot of simulators. It
also makes
it much more consistent to invoke one to run a test.
Chris Johns has started a new generation of the same idea in Python. It
has better
support for automating testing on real hardware but doesn't support as many
BSPs or features yet.
> *** HELLO WORLD TEST ***
> Hello World
> *** END OF HELLO WORLD TEST ***
>     128835  02001f38  91d02000  Address 0x0000000002001f38 is out of bounds.
> but still this (for novice misleading) error message at the end remains.
> With Qemu/Leon3 the story is probably a little bit different, I've seen
> on the mailing list some messages about a topic and although using qemu
> 2.0.0rc0 it may be the case that not all Sebastian's patches are in in
> order to have vanilla Leon3 BSP running...
> Thanks!
> Karel
> On 03/17/14 12:19 AM, Gedare Bloom wrote:
>> Do the non-"unstable" tools work for you? I don't know what the
>> unstable signifies. I use Centos 6.5 and just built my tools
>> (4.11/rtems-sparc and 4.11/rtems-sparc64) last week successfully.
>> -Gedare
>> On Sun, Mar 16, 2014 at 1:11 PM, Karel Gardas<karel.gardas at centrum.cz>  wrote:
>>> Hello,
>>> while trying source builder on CentOS 6.x on AMD64 machine I've hit
>>> following issue:
>>> ../source-builder/sb-set-builder --log=sparc.log
>>> --prefix=/home/karel/sfw/rtems-sparc-head unstable/4.11/rtems-sparc.bset
>>> RTEMS Source Builder - Set Builder, v0.2.0
>>> Build Set: unstable/4.11/rtems-sparc.bset
>>> error: unstable/4.11/rtems-sparc.bset:17: cannot find file: expat-2.1.0-1
>>> Build FAILED
>>> this is using today's source buidler head attempting to build RTEMS
>>> unstable/4.11 tools.
>>> Is there anything I may done in order to fix that?
>>> Thanks!
>>> Karel
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
